42 lightning length on trailer >
Old 07-08-2015 | 04:55 PM
Default 42 lightning length on trailer
Can any 42 owners out there give me the overall length from trailer nise to end if outdrive..... I am debating a 42 versus 38 Cig and trying to determine if can fit in my garage..... I know some trailers have slightly different lengths but want to get some actual numbers....
Thx
T
stormbauer is offline
Old 07-08-2015 | 05:29 PM
Sydwayz's Avatar
Forum Regulator
Boat plus 5 feet conservative.
Boat plus 7 feet liberal.
EoH brakes usually saves you about a foot of length on the trailer (compared to a surge brake coupler).
Welded trailers are usually a bit shorter than bolt-together.
Pending trailer type, you could have a removable tongue fabricated.
Something that would slide out of a long tube, with pull pins to keep it in place.
ITS or SSM or Extension boxes...
...go with liberal number.
Drives out can extend overall length by as much as a foot. (Many of us tow drives out to keep them away from the pavement; as such they are out when you back in the garage on the way in from a jaunt.)
Sydwayz is offline
Old 07-08-2015 | 05:44 PM
So with ssm the drives stick out about 1 ft from swim platform? Is the 42 exactly 42' from tip of beak to end of platform? I can always tuck drives when get back home...... Might need to cut pockets into garage to fit drives in between wall joists😁😁😁
I have seen a few pivot tongues on trailers but not for this size.... Need some additional research, i guess
Old 07-08-2015 | 07:52 PM
Mine was 46 1/2' from ball to props with drives up. Depends on the brand and placement of the trailer.
shark42 is offline
Old 07-09-2015 | 06:02 AM
What drives did you have?
Old 07-09-2015 | 08:21 AM
Bravos
shark42 is offline
Old 07-13-2015 | 11:43 PM
I just bought a 42 with an aluminum Myco that has drive guards.... it is inches from 48 feet from tip of the of the coupler to the backside of the drive guard.
got twins ? is offline
