Hull thickness >
Hull thickness
Hull thickness
Old 08-11-2015 | 02:03 PM
Originally Posted by 682gold
I have gotten my thru hull water pickup. I am determining where I want to drill my hole. I know I need it as close to the end running surface as I can get it. It is a 2000 38' Lightning. I plan to be within 20" of the end of running surface just at the engine. How thick is the hull in that location. I know I will find out soon enough but am looking for a little heads up.
Mine is not a good comparison with yours because am running a straight bottom 35 to your step bottom 38 , I figured the back of my boat is the deepest so that is where I mounted my pick-up's and I will see how they work,.If they do not work good I will have two more holes to fill .
green lightning is offline
Old 08-11-2015 | 03:41 PM
Fiberglass is a wonderful thing. I did look at the notched part of the transom where I would have to mount them and there is not a ton of room there. I will com straight up then SS ball valve, street elbow with barb right into the strainer. We shall see. Hell we got VERY low water at the lakes around here. Not hurting my feelings that its on trailer right now.
682gold is offline
Old 08-11-2015 | 03:57 PM
Originally Posted by Rattlesnake Jake
Your boat, but I would go with the old reliable transom mount type. Helluva lot thicker and stronger there than the hull bottom.
Just my thought.
I'd rather mount it in solid fiberglass than compromise the transom area. I'll do just about anything before I open up the wood even if it's only a screw hole.
payuppsucker is offline
Mine will be trial and error I don't think my adjustable pick- ups go up high enough so they might have be cut and rewelded back together .
Old 08-11-2015 | 05:01 PM
I can tell you this from experience. the pick up from CP are great for a none step FPB they work great. if its a step bottom they will never work.
jerryhaney is offline
Old 08-12-2015 | 12:22 PM
I think I heard screeching brakes.
Old 08-12-2015 | 04:20 PM
Nope, Just drilled my holes and getting a new tube of 5200 to set it with. Putting my ball valve and barb fittings together. Gonna try and see. There is nothing I can screw up bad enough that I can't pay someone to fix!!!
682gold is offline
Old 08-17-2015 | 05:02 PM
Did you get it in the water to test it yet Kearns? I'm curious since JerryHaney made his post.
Old 08-19-2015 | 09:10 PM
Not yet. Set the flange with bolts and 5200. Letting the 5200 set up properly before i clean the hole up from any 5200 overflow. I will hopefully run this weekend. I will post the results.
682gold is offline
Old 08-20-2015 | 09:28 AM
Ok, Looking forward to hearing positive results.
