Water pressure relief >
Old 10-06-2015 | 08:23 PM
Default Water pressure relief
Along with lines off the back off intake to Bleed off water pressure any one bleed water from a block drain to threw hull fitting to get Water pressure acceptable
BLUEMAGIC is offline
Old 10-07-2015 | 06:51 AM
got cross over with restrictor to build heat
Old 10-07-2015 | 10:55 PM
Not trying to be an a$$ but, if your having that kind of issues with water pressure, then you need to revisit how that thing is plumed. Are you dragging an offshore style pickup to low? If your getting water from stock drive pickups .. you can tap & plug some of them... If you explain your setup more in detail I can help you more
Bawana is offline
Old 10-08-2015 | 06:03 AM
got transom mounted pick ups with sea strainers. if i raise the pick ups up any more they get aerated water and my temps rise, too big of a restrictor any my temp doesnt even move. curios if a spitter off a block drain with shut off valve to regulate would help
Old 10-08-2015 | 06:08 AM
already have 4AN bleeders off back of intake wich helps want to to bleed off a liitle more pressure, any other place i could bleed off pressure if not a block drain
Old 10-08-2015 | 06:48 AM
Could go up to -6 off the intake.
Unlimited jd is offline
Old 10-08-2015 | 03:14 PM
ok sounds good
Old 10-08-2015 | 04:14 PM
just curious if bleeding off a block drain with shut off valve to regulate would be acceptable to get 20 lbs at wot
Old 10-08-2015 | 04:26 PM
Check out Hardin Marine or their selection of pressure relief valves
http://www.hardin-marine.com/c-121-p...ef-valves.aspx
speicher lane is offline
Old 10-08-2015 | 04:35 PM
You don't go off the block drain because you want as much cool water to go through the heads. If you can't raise your water pickups then go to a 6AN line coming off the back of both sides of the intake manifold. What kind of exhaust are you running?. You want as much water going through the motor & exhaust as possible. With a system that is set up properly the motor will keep a consent temp and bypass water to the exhaust when stat is closed. Problem with not running a stat is hard to keep it from stalling at the docks, and condensation in oil. On a old setup I ran I used 6AN lines coming off back of intake that were T'd into a pressure relief valve that went to a 10AN line out the back of the boat. That way it dumped only when pressure got up to over 20 psi.
Bawana is offline
