Has any one taken out flaps in tips? >
Old 11-15-2015 | 02:53 PM
Default Has any one taken out flaps in tips?
I changed from gill exhaust and went to stainless marines with a higher pipe system. I probably gained another 5" in height off the manifold. Do I still need the flaps in the tips ? I have rubber flaps on the end of the tips also. Any experience with removing ? I belive I am loosing some power.
Drew555 is offline
Old 11-20-2015 | 06:28 PM
we removed the internal flappers on mine when it was stock years ago .they were leaking so we took them out and welded up the holes where the pins went thru. i have 3 seasons on 600+hp 540s with gil exhaust and the same tips with just the outside flapper. no issues .
flat rate is offline
Old 11-20-2015 | 08:04 PM
Any increase in power or air flow that you noticed?
Drew555 is offline
Old 11-21-2015 | 12:16 AM
no difference
