Anyone know how to disassemble engine hatch? >
Old 05-06-2016 | 04:52 PM
Default Anyone know how to disassemble engine hatch?
I have a Fountain fever 29 and I want to have the back two sections of the sun pad refinished with the fountain logo. I figured it would be easier if I just take the two sections off the engine hatch and bring them to be upholstered. Has anyone ever disassembled a hatch? Is it a matter of just removing the plugs on the underside of the hatch to access bolts? Thanks
RuninaFever is offline
Old 05-06-2016 | 07:17 PM
Yes, remove the plugs (there may be some hidden under the gasket), then remove the nuts.
Ryan
Ballistic Beak is offline
Old 05-06-2016 | 07:40 PM
blownincome's Avatar
Ryan
What he said
blownincome is offline
Old 05-06-2016 | 08:32 PM
Ryan
Ok thanks... So there's no screws or anything around the sides?
Old 05-06-2016 | 09:11 PM
the rear most pad may have metal trim around the perimeter at the stern. I don't remember if it has to come off before removing the pad, or if it will come off with the pad. Mine is a 95 - I'm not even sure if that piece is still the on newer boats.
Ryan
Old 05-07-2016 | 07:26 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
The metal trim stays attached to the hatch. Just remove the plugs and then nuts
US1 Fountain is offline
Old 05-08-2016 | 07:23 AM
Just pulled the back piece off my 29 to have the dove tail piece of wood replaced and it's as simple as removing the plugs and taking the nuts off, trim ring stays on the deck.
harleyrider is offline
Old 05-08-2016 | 08:48 AM
Thanks for the info, I was actually just looking at the trim piece when I read your post! That's exactly what I have to do, my dove tail piece of wood came loose as well. I'm assuming the staple came loose. Did you do it yourself or have someone do it? If you had someone do it how much did they charge you so I have an idea? Thanks
Old 05-08-2016 | 09:09 AM
Ginger or Mary Ann?
I had to redo my 'dove tail' peice also. I think someone had sat on the hatch at 1 time and pulled up on the panel. Its just 2 pieces of plywood mitered and stapled together. Not sure who engineered that. I realigned the tail and then layed down a couple strips of glass on both sides to make it solid. Just dont run the glass to the very edge where you need to put the covering staples back in.
Old 05-08-2016 | 09:44 AM
I took it off and carried it to a local upholstery shop and he pulled the cover replaced wood and put cover back on for $75, wasn't worth my time to do it myself for him to do it that cheap.
