-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   42 Poker Run rerig (https://www.offshoreonly.com/forums/fountain/343368-42-poker-run-rerig.html)
KWright 06-01-2020 08:28 PM
Originally Posted by speicher lane (Post 4741675)
Question - On the Cats, Skater in particular is ramping the water pickups - Any fountains have this as that looks like its deep to be extremely functional but scrub mph at the same token?
although it doesn't show well in the picture we do have about a 18 inch lead in. Unfortunately we had to go that deep to get enough water pressure for both engines. I only run 1 very large sea strainer.
https://cimg9.ibsrv.net/gimg/www.off...fb275883bd.jpg
https://cimg2.ibsrv.net/gimg/www.off...4bffc50ccf.jpg
kvogt 06-02-2020 07:25 AM
What size water line are you running?
KWright 06-02-2020 01:22 PM
-20 from pickup to sea strainer then -20 out to each pump.-20 to bell housing then 2 -16 to cross over. 2 -16 from intake to exhaust.
kvogt 06-02-2020 04:23 PM
Is a -20 big enough for both engines?
KWright 06-02-2020 04:42 PM
1 1/4 inch hose. Yes same setup that they use on the race boats. A friend owns the kilo boat it is set up same way except pickup is on the back step.
kvogt 06-02-2020 06:07 PM
measure the fittings they are smaller than the hose size by a fair amount. I'd run 1.5 inch hose.
kvogt 06-02-2020 06:09 PM
your pickup looks deep and big, so I'm thinking your restricting flow after that.
KWright 06-03-2020 07:48 AM
Yes it does look that way. But that is the end result of achieving what we were after. Our water pressure doesn't vary more than 3 or 4 pounds from 30 mph to 110 mph.
I may loose a few mph but that's ok with me I would rather have the steady pressure.
KWright 06-03-2020 08:12 AM
https://cimg1.ibsrv.net/gimg/www.off...334bcec45e.jpg
The hose connected to the shutoff valve is an air bleed. It exits low on the side so when the boat is off plane it is underwater. That way it doesn't suck air. When under way it bleeds any air that is in the strainer. You can fine tune your pressure by the size restrictor you use in the hose. When we are going it pushes water out this is how I am sure we have enough flow.
KWright 06-03-2020 01:25 PM
https://cimg1.ibsrv.net/gimg/www.off...199a911a5e.jpg
https://cimg3.ibsrv.net/gimg/www.off...49443a65b7.jpg
https://cimg4.ibsrv.net/gimg/www.off...0a5962380f.jpg
a few pictures of the engine bay
