Oil drain kit for 575sci >
Old 02-02-2017, 08:30 AM
VoodooRob's Avatar
Had them on every boat we have owned and zero issues. The convenience of them can't be beat. .
VoodooRob is offline
Old 02-02-2017, 09:40 AM
Received 1,331 Likes on 743 Posts
I ran mine up to a block that has them and my flush connections on it. I use a 12v pump with a quick disconnect and just punch a hole in top of filter and then hook pump up.
Oil now stays clean and is so easy to change.
Wildman_grafix is offline
Old 02-02-2017, 09:44 AM
Forum Regulator
Sydwayz's Avatar
Received 1,211 Likes on 525 Posts
And please, no comments on if Fountain specific oil drain hoses need to be longer or shorter that other boats. Some folks are sensitive!
Sydwayz is offline
Old 02-02-2017, 09:47 AM
F-2 Speedy's Avatar
Received 3,075 Likes on 1,361 Posts
the stock Merc. pans are metric correct
F-2 Speedy is offline
Old 02-02-2017, 10:03 AM
Forum Regulator
Sydwayz's Avatar
I believe you are correct.
Sydwayz is offline
Old 02-02-2017, 10:08 AM
F-2 Speedy's Avatar
12mm x 1.75 pretty sure this is it............I think I'll make some
Old 02-02-2017, 05:20 PM
All the newer Merc chit has the drain hose, most connected to allow you to pull it thru the drain plug to drain oil while on the trailer. Pretty sim[le here folks, leave the drain hose in the bilge and use it there. Mine have been just that way for almost a decade now.
RaggedEdge is offline
Old 02-05-2017, 05:01 PM
So 12mmX1.75 for the 575sci
marcusnapier is offline
Old 02-06-2017, 05:48 AM
Next best thing since no Iron Shirts -
Highly recommend.
all the best
3pointstar
3pointstar is offline
Old 02-06-2017, 12:05 PM
Where is best place to buy the kit from?
