35 Lighting Prop Question >
Old 07-12-2017 | 03:10 PM
Default 35 Lighting Prop Question
I have a 1993 Lighting with the original 25P Mirage 3 Blades Reggie installed at the factory. Boat still has original carbed 502 Mags and Bravo 1s
Looking for higher cruising speeds and not worried so much about max speed.
Whats been tried on this hull and with what results.
Thanks board
Papasmurf is offline
Old 07-17-2017 | 09:30 PM
I'm not saying this is the answer for you but. My 29 with 454s when new was tested with 26s and ran it that way 74 WOT. My 35 has 30s and out of the hole is absolutely fantastic great mid range. Haven't gone wot because the motors are still in break in. But the test sheet says it came with 26s.
fordf350 is offline
Old 07-17-2017 | 11:56 PM
35 lightening flat bottom side by side. fresh 502's. Mirage plus 25's spinning in with prop vents open
2900 RPM = GPS 40
3500 RPM = GPS 52
Hope this is of some help
Pete35Fountain is offline
