(Post 4670010)
OP I have a brand new in the boxes 1 full set of OE lifters if you dont want to go tie-bar style, GM# 17120061
Originally Posted by s022mag
(Post 4670063)
Are those the same length? |
Runina, how many hours on the valves/lifters since last rebuild? I have a pair of 500EFI with 250 hours and trying to gauge if its 'time' or not to get the top end done....
I did my top end at around 200hrs, only because I was getting a little water reversion because of the silent choice set up and I had to pull the heads anyway because one of the exhaust ports was showing a little corrosion from the water. Did away with the silent choice and it's been all good since.
Thanks, i assume your application is salt water? I am fresh water. Going to have leak down and compression done and see where i am at and make a decision then based on the numbers.
| All times are GMT -5. The time now is 02:08 PM. |
