Fuel capacity 35 ex >
Fuel capacity 35 ex
Fuel capacity 35 ex
Old 07-02-2018 | 07:07 PM
Stock 496 ho. Running 32-3400. One gauge drop from almost half to quarter in short time then moved to e where it ran maybe 3 miles. Other gauge still showed half. Started back on one engine and slowly gauge moved to e and engine died half mile from ramp.
2john is offline
Old 07-03-2018 | 07:08 AM
I have been told you cant fill the tanks while on a trailer. the tanks are made to be filled while sitting in the water
shannon2100 is offline
Old 07-03-2018 | 05:11 PM
That’s interesting. May try to fill with gas can to see if it takes more.
2john is offline
Old 07-05-2018 | 12:57 PM
10M
I have almost screwed myself this way... Not necessarily because of the trailer, but if you fill it facing downhill instead of uphill it takes a lot less... Learned I had to pull into the gas station the other way to get it all the way full.
10M is offline
Old 07-05-2018 | 02:19 PM
I was able to put 72 gallons in each tank with mine on the trailer. Mind you it was level as the hitch is adjustable so no sag to tilt it forward. I don't know if it was ran that low on the motors or seller sucked it out. When I bought it was a little of a project so I worked on it for 2 years before fueling. I wasn't happy it was that low either way as it was full tanks of fresh fuel. So you can certainly get a good bit in on the trailer
Crude Intentions is offline
Old 07-05-2018 | 05:50 PM
Fueling on trailer. Boat sits fairly level. How much would it have to be off level to make a difference?
2john is offline
Old 07-06-2018 | 09:19 AM
My freind has a 2007 EX and he thinks 100 gallons a side. He has put nearly 100 in a side so it must be at least 100.
could call fountain.
Wildman_grafix is offline
Old 07-19-2018 | 08:40 AM
You should look into getting a Smartcraft monitor hooked up to your engines. Then you will know exactly how many gallons are used which you can just subtract from the gallons you put in.
techman is offline
Old 07-19-2018 | 08:41 PM
Will try to add more gas this weekend before heading out. Maybe it “burped” since last fill.🤨
2john is offline
Old 07-23-2018 | 03:31 PM
Topped off to top of fill inlet. Added another 10 gallons each side at slow pace. Guess I know what to do now.
2john is offline
