-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   1990 fever 29 rear engine hatch weight (https://www.offshoreonly.com/forums/fountain/373995-1990-fever-29-rear-engine-hatch-weight.html)
NickSkyline 11-16-2021 08:11 PM
Is it normal for the rear hatch to be extremely heavy? I’m curious as I tried lifting it without the actuator connected, felt super heavy
dykstra 11-17-2021 06:45 AM
Yes, it’s heavy!
boostbros 11-17-2021 07:26 AM
most often its the foam thats waterlogged
NickSkyline 11-17-2021 11:55 AM
hmm so should dry up ober winter since it’s being stored in heated garage. “hoping”
Helmwurst 11-18-2021 07:43 AM
It might, but I would store it with the hatches open to allow the water to run out. You will know in a day or so, if it water logged,
OFFSHOREJOJO 11-18-2021 08:50 AM
Wet or dry lol:evilb:My guess 500 pounds leave it open inside it will dry !They get more heavy when left outside without protection
boostbros 11-18-2021 12:54 PM
i have found it will not dry unless you remove the foam and replace or let it air dry
NickSkyline 11-18-2021 09:33 PM
I figured it should be pretty light, save some overall weight but when I tried lifting!! I was very surprised how ridiculously heavy it was lol
Scarab28 11-22-2021 11:22 AM
Fiberglass alone is really heavy!
Padraig 11-22-2021 02:14 PM
I have often wondered about how to make a strong but lightweight engine hatch. One you could walk or lay on. Factory hatches or ridiculously heavy. Seems like an opportunity to save weight where it matters, the stern.
Padraig
