29 fever
Old 02-21-2022 | 01:24 PM
whw
ere did you see the 32?
ellwood is offline
Old 02-21-2022 | 04:57 PM
68 is pretty bad with a 525, regardless of temp, something is wrong there. That’s 496 speed. I have two buddies with 525s going 79 and 80 which is pretty normal. I have a 24 hydro and I easily hit 70 before I even start trimming the boat. Tabs at 2.5-3 and I’ll pull the drive to 5 depending on conditions.
RuninaFever is offline
Old 02-21-2022 | 05:01 PM
Keep in mind the the swim platform of a 32 sits extremely low in the water and the cockpit of a 32 is the same size as a 27. It’s very small. You won’t see more speed with those motors in a 32 compared to 29 single with right motor. 29 to a 35 is the only move that makes sense when going bigger.
Old 02-21-2022 | 05:17 PM
F-2 Speedy's Avatar
Originally Posted by DallasBAJA
What prop are you running on that to hit 76? I have a 2003 with a 525 efi and was only able to get 68 out of it at the shootout. (It was hot outside and very humid, which I am sure played a role, but wouldnt think 8mph difference) I was turning 5200 RPM.
Sorry to hijack OP.
plus your probably 50 hp more than the 500
F-2 Speedy is online now
Old 02-21-2022 | 05:45 PM
30 hp difference between the two and the 525 is supposedly close to 100lbs heavier
Old 02-21-2022 | 05:51 PM
F-2 Speedy's Avatar
the 525 will dyno out 550 + been posted on here
Old 02-21-2022 | 06:17 PM
so, anyone know what to do to add like 50 hp to a 496 ho? had a fountain with the 496 and couldnt get it running over like 62.. any suggestions? it was an brand new x drive and i believe a 26 bravo 4 blade. just didnt seem like the motor had enough oooomph for the boat....... thoughts?
ellwood is offline
Old 02-21-2022 | 07:22 PM
29' Fountain faster then a 27' single or a 32' twin equal power Get a 29' with twin small blocks if any out there!?
Nothing personel 353 is offline
Old 02-21-2022 | 07:49 PM
A 525 has aluminum heads so it should be about 75lbs lighter than a 500 efi, not 100 lbs heavier.
ttuton is offline
Old 02-22-2022 | 11:15 AM
Originally Posted by ellwood
whw
2003 Fountain Fever 32 - Boats - Evergreen Park, Illinois | Facebook Marketplace | Facebook
TexomaPowerboater is offline
