Confirming prop rotation >
Old 06-14-2024 | 12:17 PM
Default Confirming prop rotation
Just confirming 1997 Fountains ran the twin props so when in forward the tops of props spin inward and down. Sound right? I believe this creates stern lift. Marina asked me how I want them to install my props so I want to get it right. Thank you!
Pat Ousborne is offline
Old 06-15-2024 | 05:31 PM
Depends on how your out drive shift linkage is set. Could be set to spin in or out. You can run the engines on a hose and shift into forward to confirm which rotation you have. My Fountain did spin in.
Interceptor is offline
Old 06-15-2024 | 07:00 PM
that is inward rotation and in draws the rear end down/ gives trim
leverage
JaayTeee is offline
Old 06-17-2024 | 01:02 PM
I've always heard turning "IN" gives a slightly better top end speed at the expense of low speed maneuverability (docking manners), at least on the Fountains..
zz28zz is offline
Old 06-19-2024 | 05:46 PM
Sounds correct.
Old 06-19-2024 | 05:52 PM
Trim out when docking and you will not even notice it.
at least I don’t, having tried both.
I am either very good at docking or very bad! Lol
Wildman_grafix is offline
