Prop direction >
Prop direction
Prop direction
Old 10-07-2003 | 09:58 PM
  #31
US1 Fountain's Avatar
Ginger or Mary Ann?
Originally posted by gferdon
Let's see if I have this right. I am currently spinning in...to spin out I need to swap the props and flip the cables at the shift levers on the dash for proper lever action. Any idea how to switch the cables??
Also, what model are you running?
Gary
Yep, just move the shifter cable from the bottom to the top on one side, and opposite on the other. It is very clear once you look under the dash at the current config.
It is easiest to remove the 4 screws that hold the shifter assembly to dash and lift out far enough to get to the cables. It's a 10 min job. Might try the swap, I lost no speed.
Mine is a 32'.
US1 Fountain is offline
Old 10-08-2003 | 03:53 PM
  #32
gferdon's Avatar
Thanks for the heads up, weather permitting I will give it a try this week. BTW what kind of power are you running and is your 32 a stepped or unstepped hull? I am told the speed difference is significant on the step and not so on the normal bottom. My 29 is a new step hull.
gferdon is offline
Old 10-08-2003 | 05:17 PM
  #33
Ginger or Mary Ann?
Stepped hull. twin 502's
Try it, you'll like it!
Old 10-09-2003 | 05:12 PM
  #34
gferdon's Avatar
Looked at the shifter system, no problem to change it in position just like you said. Before I do tha I will just switch props and shift backwards to see what gives with the speed and handling. Let you know what happens.
G-
gferdon is offline
JJONES
Prop Talk
7
04-18-2006 07:13 PM
islandracer
Sonic
3
03-16-2006 08:06 PM
epeek
Fountain
22
01-22-2005 11:10 AM
flylevel
04-03-2003 11:55 AM
HOTROD2
20
02-10-2003 07:13 PM
