Throttle Question >
Throttle Question
Throttle Question
Old 07-14-2003 | 07:23 AM
Question Throttle Question
Where is the adjustment on the throttles to stiffen them up? I am losing rpms while hitting waves. 99 42 Lightning 500 efi Thanks Daryl
Daryl is offline
Old 07-14-2003 | 09:16 AM
SeaDated's Avatar
Look thru the rubber boot for an allen head screw. You may have to move the throttle up to see it. Turning it in will increase the spring pressure to the piston which will increase the friction.
I had one of the spring break so if you can not obtain the fell you want check for a broken spring.
Gig
SeaDated is offline
Old 07-14-2003 | 11:21 AM
Thanks I'll Check Wednesday.
Daryl is offline
Old 07-17-2003 | 06:36 AM
Default Throttles Part 2
The set screws were the ticket Thanks! Now what is the correct way to adjust the throttles to keep them even, level at same rpm.
Daryl is offline
cstobe
Prop Talk
1
05-17-2006 02:26 PM
two-air
Prop Talk
2
04-06-2005 11:55 AM
WHITE-DIAMONDS
8
12-16-2002 03:42 PM
WHITE-DIAMONDS
12-12-2002 04:59 PM
ScarabMike
Scarab
2
03-20-2002 10:05 PM
