Bluprinting My Hull and...........
#51
Originally posted by StrikinLightnin
Scott,
You know your always welcome.....
BUT bring your stocking cap,,,,,
I want to run early to see what the props are doing.
Going to have Precision Propeller in Indy blueprint them.
Scott,
#55
Updates??????????????????????????????????????????? ???????????
#56
I know I know
I stopped over a few times and they were having problems getting a match for the gel.
They finally got the right stuff and sprayed the bottom.
I believe they used Mini Craft for the Gel.
I had concerns about thickness of the gel
and they sprayed and sanded three times with seven
coats applied each time instead of two and seven.
I'll try to get some pics next week.
#60
Originally posted by j winkelman
I CHECKED THE BOTTOM OF THE BOAT AND IT IS STRAIGHT.IS THERE ANY MPH TO BE GAINED IN BLUEPRINTING THE BOTTOM OF MINE TO MAKE SURE IT IS TOTALY FLAT WITH SHARP EDGES?
Are you sure that the entire running surface is straight?
