-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Raddle in the swim platform?? (https://www.offshoreonly.com/forums/fountain/69612-raddle-swim-platform.html)
JohnnyMarshall 01-21-2004 08:33 AM
A New raddle appeared in the swim platform does any one know how to fix it. I thought it was the engine hatch and i replaced the hinges but that did not do it. Please help.
BAJA WILL 01-21-2004 05:16 PM
I have seen this happen on a Baja, the solution is
1. Remove ladder, what my friend did
2. Or wedge a small towel in there to hold everything tight
Will
JohnnyMarshall 01-26-2004 12:19 PM
We have no ladder so that can not be it but thanks anyway.
BAJA WILL 01-26-2004 04:47 PM
Johnny,
Sorry I assumed you had the integrated platform:crazy: I would say check you headers and all the bolts in the engine comp:rolleyes:
WILL
US1 Fountain 01-26-2004 05:22 PM
What size boat?
Silent choice?
Weather stripping for engine hatch seal missing or out of location? > engine hatch rubbing against engine
compartment opening drain ledge.
fourplaydave69 01-26-2004 06:59 PM
rattle
At what rpm do you hear this?
45sonic 01-27-2004 09:48 AM
Re: rattle
Good question
I had a very annoying rattle at low rpm's. Found out it was the integral exhaust flappers for the silent choice thru the props had worn out the bushing and were just a rattling away.
Hope that might help
JohnnyMarshall 01-27-2004 10:54 AM
US1 I have a 32 with silent choice along with stripping, and 4 play dave the raddle occurs only at idle. I sounds like maybe the platform is raddling where the top and bottom of the boat is attached. Thanks for the help guys
rchevelle71 01-27-2004 10:59 AM
Exhaust flappers!!!!
Drove me nuts, thought I had a serious problem.
If you can get to them, wedge something in there to hold them open, fire it up, and see if rattle is gone.
worked for me!!!
JohnnyMarshall 01-27-2004 02:57 PM
rchevelle Thanks alot that sounds right. I can not wait to try it when it gets a little warmer. Does that mean new flaps are necessary.
