Replacing Rotted Transom >
Old 04-19-2004 | 08:10 PM
bryanspeedracer's Avatar
Default Replacing Rotted Transom
Some of you may have been following my progess on the '84 10 Meter I bought in Feb.
Things have been going as planned. Motors are coming together, dash, throttles, and gauges are on their way.
Today the weather was nice. I went to work on the engine compartment. Cleaning, disassembling getting ready for bilge paint. The boat I have, has a fresh water flush starboard side near the rub rail. I pulled it in the process of cleaning.
I found that the wood core was VERY wet near the hole. I did some poking and the wood is rotted to the exhaust cutout. Checking further, the wood is rotted as far down as I can stick my finger. As I bang on the hull with my fist, I have a hollow sound nearly to the K-plane/drives. I pulled all of the exhaust tips, same thing. The port side is only slightly less rotted in the same areas. The area between the drives seems ok, although it's academic at this point. I need to replace the transom core. The gel is in perfect shape as is the interior glass (no cracks anywhere).
I'm looking for guidance. I will tackle this job, with help. Who has done this? What would you do differently? How did you do it?
Thanks for the help...
bryanspeedracer is offline
Old 04-20-2004 | 05:24 AM
blownincome's Avatar
You might want to poll the whole board on this one. I have seen it done and the process was not pretty, cant speak from my own experience though..
Good luck!!!
blownincome is offline
Old 04-20-2004 | 08:27 PM
32storm's Avatar
You may want to have Watercraft Clinic, Red Creek, look at it or Great Lakes Boat Repair, Sodus Point. See tech section. At least you found it early enough before season starts.
32storm is offline
Old 04-20-2004 | 09:23 PM
Bryan...
I have not had to do this job yet, but I do know someone that did. I would have it tested with a moisture meter to see how far it goes. I would cut the fiberglass away on the inside of the transom. Then you can remove the core in small pieces with a chisel and lots of muscle. The core is made up of two pieces of 3/4 marine plywood epoxied together. I did fill in my exhaust and steering cylinder holes to relocate them. I moved the exhaust because when I was idling around the docks my wife would get soaked from the pipes being in the water. I moved the steering cylinders to the outside when I installed Marine Machine steering. I will ask my friend if he has any other tips for you. We can talk about installing new core and doing glass work next time.
Steve
Steve Conniff is offline
Old 04-20-2004 | 09:46 PM
Ted G's Avatar
Pick up a copy of West System's Fiberglass Repair Booklet (any store that sells West System). There is a great section on rebuilding transoms. You don't have to use West, but it is really great stuff to work with and I would recommend it. Do check the stringers also, a friend of mine just had his transom and all stringers done last year in a 13 Meter. The stringers were rotted 10 feet up from the transom and 8-10 feet back from the bow. Any place you suspect, just drill a small hole into the area and see what the wood is like that comes out.
www.cbpba.com
Ted G is offline
Old 04-21-2004 | 08:02 AM
Thanks guys. I'm going to dig into it this weekend. I'll post some pics when I get it apart. I have to believe that rot has to be at least a concern in any boat this age. To me, it makes no sense to bad-aid it. It's just disappointing. Fortunately, materials won't be out of sight expensive.
Old 05-01-2004 | 10:06 PM
Allrighty then,
Let me appologize right now for no pics, problem with program
Anyway, the transom was stripped, Thanks for the help Jim...
I cut the inner sheet of glass (liner of sorts). I cut it very close (half inch?) to the hull sides and then around the stringers, finally across the top of the transom sheet. I got the glass out in one piece, yipee
I pulled all of the wood core out of the transom. I used a prybar and hammer. The wood came out reasonably well. In fact, all of the wood has been cleaned out down to the glass. One stringer is just alittle soft, the rest are good. This isn't all that critical as each stringer will be cut at an angle to facilitate setting the new wood in place. You guys should see the wood that came out. It was like mulch. There was NO dry wood anywhere. Unbelievable.
This job is taking some time, but definitely managable. I am going to use epoxy for bonding.
I promise to get photos up. Sorry for the length, but I have to believe that there are others with the same problem. If you have some experience and confidence, anyone can do this
Old 05-04-2004 | 04:00 PM
Lofty's Avatar
You're making my stomach hurt just thinking about a rotted transom. I read this thread yesterday and spend last night sounding my transom. Thank God it's all dry!!!
Good luck with the project and post some pics would ya'!
Lofty is offline
Old 05-05-2004 | 12:29 PM
Believe me I was sick. Fortunately, the motors were already out. Tomorrow, I will finnish preping the glass surfaces and begin a template for the new wood. I will do a few dry runs for a good fit and finally epoxy the two pieces of wood together. I am using 2 x 4's through bolted to create a sandwich (uniform press.)
I promise to post pics. Bryan
Old 07-02-2004 | 08:55 PM
Default Re: Replacing Rotted Transom
Check the tech section. I posted pics of the transom project...
alecsammy
11
11-04-2006 03:57 PM
bryanspeedracer
71
10-11-2006 03:29 PM
ippon
5
10-01-2006 09:01 PM
kmiller
37
07-22-2004 09:23 PM
HOTTZU98
5
06-19-2004 09:16 PM
