alternator prolbem >
alternator prolbem
alternator prolbem
Old 01-20-2005 | 09:33 AM
50boat's Avatar
Default alternator prolbem
when master switch is turned on to both, alts smoke. when turned to 1, its ok. batters are new .Also, where are the oil temp sending units located on hp 502? 1996 42 Lightning
50boat is offline
Old 01-20-2005 | 11:22 AM
pachangalpina's Avatar
Default Re: alternator prolbem
The sender should be on the oil filter housing. Good luck with the battery switch, not sure what that problem is but make sure all of your grounds are good.
pachangalpina is offline
baja27
0
09-23-2008 08:57 AM
David Stotz
11
12-16-2007 12:43 PM
itilldo
07-06-2006 07:44 AM
WHOSNEXT
15
09-30-2005 10:50 AM
timewarp
3
03-03-2002 09:31 AM
