502 sounds like it has a mis >
Old 04-17-2005 | 10:10 PM
t500hps's Avatar
21 and 42 footers
Default 502 sounds like it has a mis
Out running today, trying to keep up with Excursion and ended up idleing back to the dock. Starboard motor shut down and sounded pretty bad when we got it running. Pulled the plugs and 3rd one back on the right side didn't look to good. A couple of the guys with me today may have a better idea if this might be my only problem????
Russ C.
Attached Thumbnails 502 sounds like it has a mis-dscf0004-small-.jpg   502 sounds like it has a mis-dscf0009-small-.jpg
t500hps is offline
Old 04-18-2005 | 08:43 PM
Default Re: 502 sounds like it has a mis
When you say third one back, do you mean facing front or back, if its #6 and you have a mpi with a vst set up the diagraghm could be bad in the vst, or it could be a bad plug, plug wire, dist cap. Worst case scenario you burned a piston, check you your compression to find out. Need some more specifics.
RonS is offline
glassdave
06-26-2007 02:29 PM
PatriYacht
5
11-17-2004 06:43 AM
glassdave
02-13-2003 09:54 AM
Rambunctious
05-29-2002 01:13 PM
