Speedmaster lll Tools Wanted >
Old 06-09-2005, 03:32 PM
Exclamation Speedmaster lll Tools Wanted
If anyone has or knows of any Speedmaster lll tools for sale or rent please contact me: [email protected]... I need to replace my prop shaft seals.
Thanks in advance,
Mike
autoap is offline
Old 06-09-2005, 05:19 PM
Reed Jensen's Avatar
Default Re: Speedmaster lll Tools Wanted
I have the tool that takes the nose cone off.... You can use industrial type spanner tools on the inside to take it apart. I did mine. OH... by the way... you don't have to totally disassemble the drive to remove the prop shaft and change the seals. The trick is to slide a shaft the same diameter as the prop shaft into the gears to keep everything in place. It also helps if you have a fixture that holds the drive and the prop shaft vertical. Reed [email protected]
Reed Jensen is offline
Old 06-11-2005, 06:09 PM
I hope nobody TRIPS over this thread...........
Prater
Wanted
0
10-27-2008 01:16 PM
betitbig
17
02-06-2007 03:54 AM
TastyWaves
1
07-12-2006 12:35 PM
marinetrans
General Racing Discussion
0
02-23-2006 03:46 PM
KenP
07-03-2003 02:00 PM
Quick Reply: Speedmaster lll Tools Wanted
