Need help please look at pictures
I agree with the other guys that from your pictures it looks to be a condensation build-up. I am running some oil thermostats (KE Thermofilters) and I would still get the same kind of condensation build-up in my engines on the upper end like yours, but not quite as severe as yours though. I once found it caked on the underside of my intake manifold when I removed it once. At the time I was using Valvoline straight 40w racing oil. A lot of times this will happen during long idling periods when the engines aren't building enough heat for the oil to burn off the condesation----even with the oil thermostats I had/have. However, I since I have added the 160* water thermostats I think it has helped greatly during the long idling periods. Also, I now try to idle out with as high of an idle RPM that I can get away with to keep the oil as warm as I possibly can.
At first (a few years ago) I didn't run a water thermostat because the water pressure was way too high so, I ran without them at first until we got the water pressure problem resolved. I am now using a 160* water thermostat, and my oil thermostats are at 212*. My oil coolers I think are pretty large. For the most part I do my boating in the cooler waters of Lake Michigan and surrounding areas---so I don't know if the water thermostats are helping the condesation problem at idle much though. I may even try using a 180* water thermostat. Just so that you know, this year I will be using Castrol 20w-50 oil.
If you don't have any water leaks then It seems as though your oil temperature is too cool. You should do what you can to get it up past 212 but less than 230 to boil off this condensation.
Roby
Roby
As said in prior messages. Itscondensation. You need to look at your tailpipes and manifolds. Your grtting water in the engine from somewhere. Even look at your cylinder heads. What year are your engines? Remeber, when you get moisture in the valve cover and breather it is from your exhaust or tail pipes usually and if you get moisture in the oil and dipstick tube its usually something worse.
John
John
By the way, it may help to know that I am running a completely dry exhaust system and the Castrol 20w-50 I will be using is a conventional (non-synthetic) type.
Official OSO boat whore
Hopefully it's the oil. You already changed it, so run the motors for a while and see if the goo is still there. It should be gone. It just needs a little time to redissolve and evaporate.
