Need help please look at pictures
Install a pcv valve system and your problem will evaporate in a trip or two. For now, leave the fill caps and breathers off during the week layup to let evaporation work its magic inside the engine. Also, if you made any idle adjustments to the carbs (lowered it) turn it back up to make sure this is not reversion. I would guess that is the cause myself, but pcv should do the erradicate the issue. At least it has for me in the past.
BT
BT
Originally Posted by MarkSmith
Oil thermostat keeps the oil at 200-230 degrees. Burns off the condesation above 212 degrees.
Registered User
Many things can lead to moisture in your oil. Gasket, headers,poor exhaust valves and temps. Typically condensation will form on the top of you valve covers and intakes. It typically happens more often in areas were the outside temps are cooler. Next time you run the boat get the motors up to operating temp for a period of time and see if the moisture starts to burn off. If your oil temp doesn't reach boiling point it will not remove much condensation. Most open breather motors will make condensation so I wouldn't worry to much about it. If it really bothers you K.E products offers an in-line thermostat that works well.
I did change the oil and filters ran it for over 20 minutes and oil got up to temp so did water shut it down checked the oil on the dip sticks they both looked like brand new not one drop of water. I'll change this oil now and put the mobil 1 m1-302 filters and new oil it again just to make sure.
Hey I just might sell it we want to go alittle bigger say a 38
Cigaretteman
Originally Posted by Cigaretteman
You canīt really check the oil on the dip stick since the oil in the dipsticktube stays in the tube ! Unscrew the filter and check it there that will show you what the oil is like.
Cigaretteman
Cigaretteman
BT
