Proper way to backflush 496 ho's? >
Old 06-24-2005 | 12:32 PM
Harper220's Avatar
Default Proper way to backflush 496 ho's?
Just curious about the proper way to backflush my 496 ho's? What hose do you pull and insert garden hose and what hose do you pull on the other end to let everything out? I need to get the river crap out of the oil coolers. Thanks for any advice.
Harper220 is offline
Old 06-24-2005 | 04:19 PM
Harper220's Avatar
Default Re: Proper way to backflush 496 ho's?
Anybody?
Old 06-24-2005 | 04:33 PM
MitchStellin's Avatar
If it is only the cooler just remove the hose from both sides and flush. If it is the entire engine remove the t-stat and the hose at the raw water pump and have at it. With the first way you can flush both ways and really clean it out. Do you know there is stuff clogging the oil cooler? You should be able to see thru it. If you don't remove both ends you are just pushing the crud into the raw water pump and it will be pushed back when you start it again. Do you have a circulating pump or a cross over? (circ pump looks like an automotive water pump on the front)
MitchStellin is offline
Old 06-24-2005 | 05:00 PM
Harper220's Avatar
My starboard engine is easy to remove the inlet hose to the oil cooler and remove debris and yes this is where everything gets hung up it seems. On the other hand, the oil cooler on the port engine is impossible to reach, so I need to know the proper hoses to deal with to blow the crap out of the oil cooler on the port engine? If you're facing the engine, I've pulled the right hose from the heat exchanger, but the water comes out the outdrive pick ups. I tried to pull the inlet hose off the air drain system that your fresh water comes into also, but that was a *****, so I gave up. Would this be the hose to pull to let the oil cooler crap out? If so I'll try again.
Old 06-27-2005 | 06:24 PM
Harper220's Avatar
I really thought I'd get a little more feedback on this subject...
Old 06-27-2005 | 06:26 PM
Sean H's Avatar
A to Z
might want to try the tech section, alot of those guys don't read much in the GD.... i don't know anything about the 496's or i would try to help...
Sean H is offline
Old 06-27-2005 | 06:34 PM
Harper220's Avatar
I hear ya, thanks. It's just that the GD gets so much more exposure...
bowtye8
4
08-08-2008 07:50 PM
jmeng
05-16-2007 05:44 PM
hvyhitter19
02-11-2006 08:50 AM
TEAMBAJA
11-18-2005 11:08 AM
Paul Perzyk
4
03-05-2003 09:39 PM
