Crash Victims Brother Thx
Old 07-14-2005 | 10:26 PM
  #81
Default Re: Crash Victims Brother Thx
ttt
SMOKDU is offline
Old 07-15-2005 | 12:16 AM
  #82
Need-the-Speed's Avatar
Xtreme Cooler Test Dumby
Smokdu,
If you have an opportunity to closely examine the boat, there are a few things that you may look for too answer a few q's. If you look at the helm of the vessel, you will see a drive indicator of some kind. It will be numeric. Write down the last setting or posistion of the drives. I believe numbers go from 0 to 9. In the same or very close location you will see a similar gauge for TABS. Record both of these settings. The speed of the accident will never truly be known but for your personnel info you may get a max (for the day) recall on the GPS speedo. This may give you an idea of the rate of deceleration (from 120 to 70 in 1/4 mile etc. etc.). I imagine that since they over shot the first stop, they pulled back on the sticks relatively hard. This factor could have given your brother a "false" sense that they were actually going at a slower rate than they really were as a result, he thought it was OK to make the turn. People get the same sensation when traveling on a 75mph (90mph ) Thru Way and get off at an exit with a 55 mph road. You don't realize your traveling 65. Your senses are still set for 90mph. The TAB and Drive settings will give clues if the attempted turn was properly "prepared" for or not. When a boat operator is setting up for a hard turn it is common practice to lower the drives a bit in attempt to get more "sticking power" to the transom of the vessel. The TABS don't really have much use in a turn. They are however, used to make the boat plain out faster as well as correct a "leaning" boat. The Tab reading may lend a hand in determining what COULD of happened during the spin. They could in-fact, play a large role in determining the motion of the boat during the spin.
When you look at the boat where are the cracks, holes, rips etc. etc. This will be the most important clue in determining the actual impact of the hit. If you can look at the restraint mounts, if they were in-fact wearing the restraints, you may be able to determine (Bends, holes in the fiberglass etc. etc.) which way they we're thrown. Early posts stated that all the seat backs were bent toward the bow suggesting a strong force came from the transom direction ( my previous post theory). Check the direction of the drives. They were making a turn so the drives should hypothetically (If the force of the spin didn't alter them or rip them off) still be in that direction. If in-fact they are turned in the opposite direction, it may lend clues as to whether or not your brother tried to (had time) correct the boat or it suddenly broke free. If the boat suddenly broke free it probably would have spun in a more even or flowing fashion. If he tried to correct the spin it would affect the area at which the boat impacted. Kinda like "high siding" a motorcycle. I'm not trying to sound "basic", I'm just letting you know the basic functions of different parts of the boat. If you already know..sorry. If you are able to take pics of the boat on land it would really help the oso gang in theorizing on what may have happened. Hope the info helps.
Need-the-Speed is offline
Old 07-15-2005 | 12:33 AM
  #83
God-speed to your brother, and best wishes for long, happy and fulfilled lives for your entire family.
Dave and Jamie Novick, SoCal.
dave911 is offline
Old 07-15-2005 | 07:52 AM
  #84
racer-x6's Avatar
Originally Posted by n2boatn2
Racer-x6 I'll go along with your statement ,sometimes what we say or (type) isn't what we meant or it was perceived wrong. So x6 how are we to take the statement quote from Bigyellowcat I ADVISE YOU,, In a time of most grievous emotions ,closer is what Mark and his family are after,,
Bigcat if or when you have a son and God forbid he were to be killed in an accident ,, please post to us your feelings . Mike and Mark were twins if you have any experience with them it's like dealing with ONE. We including myself can't say how we would feel or what we would say until we are put in the same pair of shoes. And I will clarify any misunderstandings about my statement about DEEEEP pockets
Just because you have a BIGYELLOWCAT or a big fast boat period,, and you think your packing big bucks,, look at what happened Saturday money has never cheated death don't think it want happen to you. When you think your BIG with a pair of $ 60k engines let me show you my six figure motor coach, and my equally expensive twin engine Cessna.etc. etc. When I want to be humbled I look at Boone Pickens and think how insignificant my net worth really is!
I am relatively new to high performance boating, and really don't know my ass from a boat paddle when it comes to what happened on Saturday morning,, could I have done any better HELL no ,,worse . I'm thinking that BYC feels that Mark was fishing for info to blame someone,,I steal don't see it.
Since you talked to BYC on the phone and everything is cool, there is no need to respond to your post except to say, for myself I try and find the best in people until the prove otherwise.
By the way when are you going to take us for a ride in that Cessna
racer-x6 is offline
Old 07-15-2005 | 09:50 AM
  #85
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Originally Posted by Need-the-Speed
Smokdu,
When a boat operator is setting up for a hard turn it is common practice to lower the drives a bit in attempt to get more "sticking power" to the transom of the vessel.(
I thought this was the procedue for a conventional deep v but not what you wanted to do in a stepped hull.
By trimming in the bow goes down and the air trapped under transom moves forward under the hull moving the point the boat will spin around further towards the bow
Could some one explain if this is correct or not
klaw is offline
Old 07-15-2005 | 10:03 AM
  #86
racer-x6's Avatar
From what I read in other post, trimming down is not what you want to to. By trimming a stepped hull down it will pick the back up and make it spin out faster. You should keep the drives in the same trimmed position for turning as you were running at.
Is this correct?
racer-x6 is offline
Old 07-15-2005 | 10:27 AM
  #87
WARPARTY36's Avatar
Drive to arrive alive!!!
We can theorize all we want, but it will probably take a while for the authorities to find out what REALLY happened.
In wondering what your brother was thinking or feeling at the time. I was in a similar situation a couple of years ago and spun out in a turn at 60 or 65 mph. All of us were thrown clear with no jackets and by the grace of God, not one of us were injured or even scratched. There is no thought or unsafe feeling. It happens SO FAST!!! There is no time to react or think for that matter. In my honest opinion the last thing he remembered was being in the front of some of the baddest boats on the planet with a smile from ear to ear!!!
I hope this helps, and my deepest condolences.
WARPARTY36 is offline
Old 07-15-2005 | 10:30 AM
  #88
SCRAPMAN1's Avatar
Trim Angle Depends On The Set Up Of The Boat As Well As Conditions But Generally Speaking A Hard Turn Should Be Attempted At Level Trim Or Slightly Tucked In. This Applies To Stepped Hulls As Well.
SCRAPMAN1 is offline
Old 07-15-2005 | 11:15 AM
  #89
We spun out last year at the worlds in Key west, running about 80.
You have very little time to react, or even think about it. But in my case for a split second ( in your mind ) you know something is not right. The next I remember is floating in the water wondering what the hell just happened.
We were very lucky we weren't hurt. But we also had helmets and the big lifeline jaclets on.
wcmarine is offline
Old 07-15-2005 | 03:20 PM
  #90
n2boatn2's Avatar
Talking Re: Crash Victims Brother Thx
X-6 We need a big party somewhere centerally located for everyone to bond alittle
n2boatn2 is offline
