blackhawk drives
Old 07-28-2005 | 07:21 AM
p29steve's Avatar
Default blackhawk drives
does anyone know about blackhawk drives? i have one with the prop shaft wiggles slightley and the two props rub so slightley together. any suggestions?
p29steve is offline
Old 07-28-2005 | 07:43 AM
Airpacker's Avatar
Default Re: blackhawk drives
Get it apart and checked. Sounds like you have a bearing between the shafts gone. Mine are perfectly tight, no lateral play at all.
Airpacker is offline
Old 07-28-2005 | 09:12 AM
p29steve's Avatar
thanks, i will get it checked
p29steve is offline
Old 07-28-2005 | 12:58 PM
Official OSO boat whore
Sounds like a bad bearing to me. Get ready to spend some dough too. You will proably end up rebuilding the entire drive before you are done. Post back on the board if you run into any problems getting parts.
Cord is offline
Old 07-28-2005 | 01:46 PM
onesickpantera's Avatar
I don't know what you mean by "wiggles" but my blackhawk had slight play between the inner and outer propshaft. If I remember correctly there is supposed to be a few thousandths of an inch there.
Did you check your thrust washers?
onesickpantera is offline
Old 07-28-2005 | 03:05 PM
p29steve's Avatar
THANKS WILL DO
p29steve is offline
Old 07-28-2005 | 03:06 PM
p29steve's Avatar
[QUOTE=noboat]I don't know what you mean by "wiggles" but my blackhawk had slight play between the inner and outer propshaft. If I remember correctly there is supposed to be a few thousandths of an inch there.
Did you check your thrust washers?[/QUOTE
yes the thrust washers are ok
p29steve is offline
Old 07-28-2005 | 05:19 PM
asg
Also dont forget the washer between the props.
asg is offline
Ricochet
Drives and Lower Units
38
01-09-2018 10:34 AM
TexomaPowerboater
Sonic
10
06-16-2007 05:57 AM
speedchangesyou
8
04-01-2005 06:14 PM
mhunter
07-14-2002 12:35 PM
283CHECK
02-28-2002 12:25 PM
