Aftermarket fuel tanks for GMC?
I just ordered one of these. I also bought the gravity feed install kit for the Chevy. I will have 86 gallons which should take me 1500 miles unloaded and over 1100 miles towing the boat. I looked at this brand in the store and they look really well made.
http://www.northerntool.com/webapp/w...ormics&afsrc=1
I'm glad you posted Northern's website. I was about to look for it.
I made one myself last winter. I've got a hard folding bed cover on my F350, so I use the bed cover as the cover for the top tool box. I can hold 85 extra gallons of fuel and either transfer it to something else with a transfer pump or flip a switch in the cab and pull out of the spare tank into the fuel system.
Originally Posted by Semper Fi
Does anyone know who makes an aftermarket larger fuel tank for a 2005 GMC 2500HD? I have a shortbed with a small tank...it's only 28 gallons. I either want to replace the tank or put one in the bed of the truck that you cannot see fom the side. (I don't want it visible)
Any suggestions? Thanks
http://www.transferflow.com/
Another company is http://www.nwmp.com/ But they do not seem to be interested in the newer update systems
And another.....http://www.aerotanks.com/tanks.html
That's about all I could find that really care and do anything with fuels.....with the EPA and DER rules, it makes it really hard.
No more manual switching unless you do it yourself, everything has to electronic and tested under government
rules
Keep us updated on your quest
JB
PS..Sorry for the repeats....I didn't read the entire thread until after I posted...But hope it helps
Thanks guys for all the info. The Transfer flow is approx. $1,250 installed for a 48 gal tank and the Aerotank's is $1,100 installed. These are replacement tanks for the original. Yes, my truck is a diesel also.
I have decided on the replacement tank because my truck has a 6" lift. I couldn't reach into the bed to re-fuel the tank without the hassle of climbing into the bed first.
The one one that Northern tool had is plumbed into your fuel system. You simply flip a switch in the cab. Even makes your stock fuel gauge read the aux tank. I have an aditional transfer pump on mine.
You would have to get up into the bed to fill it though.
Well it says 44 gal on the tag but I have put 47 in and had room. There is an in tank mod that allows the extra to go in and lets you fill faster, the last 5 gal takes about 10 min but with the mod it takes 1. Go thedieselstop.com and look up the in tank mod. You have to drop the tank but when empty it is not bad, the skid plate was the worst part.
SLINGSHOT
02-10-2005 07:32 AM
