Eliminator Defies Laws of Physics >
Old 11-10-2005 | 09:27 AM
Sean H's Avatar
A to Z
Default Re: Eliminator Defies Laws of Physics
the same issue has a dcb 29 running 121 with ilmor 625's and herrings..
Sean H is offline
Old 11-10-2005 | 09:36 AM
Spectre Man's Avatar
Originally Posted by JasonSmith
It seems to be a push at the least. The same boat with 496 HO's will do 105mph+/- right????
This is a monumental difference between 105 and 120! Anybody that has driven at both of those speeds can verify this is like night and day.
In addtion, the article says the 525 was doing 5,800rpms. Take a look at the 525 specs posted by Mercury high Performace Marine... and then me how the 525 on the Eliminator was doing 5,800rpms at 525HP!!!! Sneaky little stinkers!
Specifications
HP: 525
kW: 410
Full Throttle RPM Range: 4800-5200
Displacement Liter/CID: 8.2/502
Bore & Stroke (in): 4.47/4.00
Bore & Stroke (mm): 114/102
Compression Ratio: 8.75:1
Cylinders: V-8
etc. etc. etc.
Spectre Man is offline
Old 11-10-2005 | 09:38 AM
BLee's Avatar
Charter Mod
Originally Posted by Spectre Man
I think they have finally lost me as a fan and probably have lost the trust of many of thier readers.
Took you long enough.
Powerboat has always been........
BLee is offline
Old 11-10-2005 | 09:39 AM
DCB advertises on the mags back page and is one of Powerboat's biggest advertisers. This boat should be running at least 170mph. My friend has a 34' DCB which is supposed to run in the mid 150s. My Spectre runs 125mph any day of the week and he is yet to beat me.
Old 11-10-2005 | 09:41 AM
Sean H's Avatar
A to Z
Specifications
HP: 525
kW: 410
Cylinders: V-8
etc. etc. etc.
the article and the spec sheet say 5400 rpm...
Sean H is offline
Old 11-10-2005 | 09:43 AM
ratman's Avatar
im suprised you all dont realize thier using speedwax on everyone of these boats b4 they test em. also if your add four onces of speed wax to the oil on your 525's you WILL pick up 600 to 800 rpms, lil duece rules
ratman is offline
Old 11-10-2005 | 10:01 AM
And they claim that 29' DCB on the cover is going for 340K it's a lake boat for Christ sake.
Anarchy Powerboats is offline
Old 11-10-2005 | 10:10 AM
Airpacker's Avatar
5200rpm, 1.35:1 gears, 36p props, 11% slip = 120.12mph according to my prop workshop program. 5400 at 12% slip is 120 as well.
A 30 with 750's should be way faster than 120. My friends 30 with 575sc's runs 115 gps.
Airpacker is offline
Old 11-10-2005 | 10:19 AM
LIOPA's Avatar
LMAO 5800 RPM's out of of a 525.......PLEEEEEZ
LIOPA is offline
Old 11-10-2005 | 10:22 AM
Sean H's Avatar
A to Z
i don't know where the 5800 came from, its not in the article...
Sean H is offline
