What is the fastest single engine Offshore V Hull >
Old 11-19-2005 | 12:45 PM
  #31
Titan's Avatar
Default Re: What is the fastest single engine Offshore V Hull
Originally Posted by LIOPA
TITAN.....every post on this thread as well as most speed posts use whole numbers for MPH. If it's that critical for you I will try to find out to the 100th / second for you.
We have a 2004 35 with 525's.....93.7 GPS
Titan is offline
Old 11-19-2005 | 01:01 PM
  #32
Originally Posted by activator92
it says offshore boat not bath tub boat
Looks like if it's not an Activator it is a POS!!!!
According to your logic, I guess my Nordic is a westcoast POS.
I have been on Check300's boat and it is sweet to say the least. It is a very clean boat and you aren't likely to run into one like it.
Magic Medicine is offline
Old 11-20-2005 | 08:45 AM
  #33
mwdill's Avatar
yea,
i have seen this trend also
mwdill is offline
Old 11-20-2005 | 12:35 PM
  #34
Didnt Steve from t.m.p. have 28 phantom that ran close to 120mph?
Velocity Tom is offline
Old 11-20-2005 | 01:38 PM
  #35
375stinger's Avatar
my 18 check runs 75 ....but seriosly i think the best single to go high speeds would be 28 batboat with a turbine wit a big arneson...
375stinger is offline
Old 03-10-2011 | 08:14 PM
  #36
The record, so I've found in my research, is 130.6 set by an orange Howard bullet 28 with somewhere around 1300 hp.
lvrepoman is offline
Old 03-10-2011 | 08:26 PM
  #37
i'm sure it has changed quit abit in 6 years
mptrimshop is offline
Old 03-10-2011 | 09:01 PM
  #38
TUFFboat's Avatar
We are going to speculate a little because we simply did not try this yet, but going by the numbers and calculating using the on-line 'speed calculator', the TUFF 28 that went 95.5 mph with a completely stock Merc 525 and a mere bravo prop, is culculated to go 115 mph with the Illmor/ indy 725.
TUFFboat is offline
Old 03-10-2011 | 09:55 PM
  #39
As far as I know its the Howard.
Uncle Dave
Uncle Dave is offline
Old 03-10-2011 | 11:38 PM
  #40
Originally Posted by TUFFboat
We are going to speculate a little here but going by the numbers, the TUFF 28 that went 95.5 mph with a completely stock Merc 525 and a mere bravo prop, is culculated to go 115 mph with the Illmor/ indy 725.
Love that boat.
tabajay is offline
