Bonding advice
Old 11-26-2005 | 11:52 AM
RedDog382's Avatar
Default Bonding advice
No ... not the male type.
Had this fitting break off my SeaLand Vacuflush holding tank. Original part was $30 to replace, but it has been redesigned and superceeded to an assembly that includes the pump motor for a mere $345.
Any suggestions on bonding agent to reattach the bung to the pump body?
Attached Thumbnails Bonding advice-vacuflush-003.jpg   Bonding advice-vacuflush-004.jpg   Bonding advice-vacuflush-002.jpg
RedDog382 is offline
Old 11-26-2005 | 12:00 PM
Default Re: Bonding advice
3M 5200.....a little messy, and takes awhile to dry, but if you clean the surfaces to be sealed, it'll stay sealed for a long-long time.
Hugh
P.S. It cures quicker if you can keep the sealant wet with water.
hpoffshore is offline
packinair's Avatar
No Comment
From: This post copyright, Packinair Inc. All rights reserved.
call dave.. he turned me on to this stuff once that was bombproof.... PM me if you need his #
packinair is offline
Old 11-26-2005 | 12:01 PM
ratman's Avatar
sand it all clean then use a peice of tape to hold it in position and use jb weld. dont use the 5 minute stuff use the slow curing type. use masking tape and make a circular dam around the area so the jb weld will be very thick and have a large diameter footprint to help hold it for a long term repair. use 80 grit or rougher sandpaper and sand everything that the glue will contact. sand a larger area than you think you will need as the larger the foot print of the repair the better the odds of long term success. the sanding is important for physical adhesion. id also wipe it off with laquer thinner or similar to remove grease and wax before you sand it. good luck but you should have a great repair doing it this way. jb weld is some good chit mon...
ratman is offline
Old 11-26-2005 | 12:02 PM
ratman's Avatar
jb weld will be a much stronger repair than the rubbery 5200
ratman is offline
Old 11-26-2005 | 12:20 PM
small panel adhesive , this stuff holds anything , and i mean anything...http://www.wurthusa.com/project/en/l...th=06.0311.jpg
open87 is offline
Old 11-26-2005 | 05:04 PM
formula31's Avatar
Ive had real good luck with Marine "GOOP".
Thought it was plastic, never mind.
formula31 is offline
Old 11-26-2005 | 05:53 PM
GOODT's Avatar
use a good 2 part epoxy>>> 5200 great stuff to use on a swim platform but not for this any good two part will work good
GOODT is offline
Old 11-26-2005 | 06:37 PM
glassdave's Avatar
Neno the mind boggler
somthing from Devcon or JB Weld would be my choice.
08 OPA High Points Champion
glassdave is offline
Old 11-26-2005 | 06:58 PM
RedDog382's Avatar
Thanks for the suggestions guys.
