HELP PELASE- BALMAR (Spelling?) ALTERNATOR QUESTION... >
Old 12-05-2005 | 03:00 PM
Joe's Avatar
Joe
Offshore Cowboy
Default Re: HELP PELASE- BALMAR (Spelling?) ALTERNATOR QUESTION...
Originally Posted by audacity
warn or caution...i know it's used in law as well....but i'm not a smart man
Wow... very impressive - that's exactly what www.dictionary.com says (coincidence, or NOTTTTTT). haha.
Thanks, Joe
Joe is offline
Old 12-05-2005 | 03:28 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
The capacitors' purpose is two fold, to ease the draw and wear on your electrical system, and supply a quick and ready (and close proximity) burst of energy to your amps when you crank it, or when the base notes hit pulling big amps out of your power source. They store energy, and gradually pull their juice from your battery bank. You mentioned the big SOB batteries you have for the stereo. I would say that if your stock alternators can keep them charged, just try and stay with stock, otherwise you may overload your wiring from the alternators and battery switches to the batteries.
I took out my 2 factory batteries and replaced them with 2 blue-top Optimas in each's place, (4 total) wired in parallel.
Sydwayz is offline
Old 12-06-2005 | 08:09 AM
FeverFan's Avatar
Originally Posted by Joe
This one (Balmar Series 7 is 110). www.balmar.com
Try this link: http://www.balmar.net/index.htm
FeverFan is offline
Old 12-06-2005 | 11:10 AM
Joe's Avatar
Joe
Offshore Cowboy
[QUOTE=Sydwayz] I would say that if your stock alternators can keep them charged, just try and stay with stock, otherwise you may overload your wiring from the alternators and battery switches to the batteries.
Yep... All the wiring was upgraded (couldn't believe... some of it was 7 bucks a foot! )
Joe is offline
Old 12-07-2005 | 12:52 PM
Most of it is #1 or #2 heavy strand copper, it can take more then your alternator can ever push out.
Anarchy Powerboats is offline
Old 12-07-2005 | 08:34 PM
Andy Buzz's Avatar
I would suggest installing a battery isolator or a large relay between each pair of batteries. This will allow the alternators to charge one battery at a time. The reason I suggest a relay or alternator for switching is that if you switch batteries with engine running on a regular battery selector switch, that can blow out the voltage regulator in the alternator instantly. Most one wire alternators, must always have a battery load.
Andy Buzz is offline
Joe
0
12-05-2005 10:12 AM
rich allen
1
07-06-2005 12:49 PM
THRILLSEEKER
2
06-19-2003 04:21 PM
formula31
8
10-19-2002 10:04 AM
