Dry sump vs. Wet sump #6s
Old 01-15-2006 | 03:19 PM
  #41
SCARABJ's Avatar
AKA NORTECHJ
Default Re: Dry sump vs. Wet sump #6s
I dont think he can handle it.. you gotta admit he does look like fred flintstone
SCARABJ is offline
Old 01-15-2006 | 03:21 PM
  #42
JCPERF's Avatar
Yabba dabba doo Got your 18 X33s.Call you tommorow for your address
JCPERF is offline
Old 01-15-2006 | 03:23 PM
  #43
SCARABJ's Avatar
AKA NORTECHJ
Your the F'n man!!!! its was good to see all yall friday night i had a great time!! ill call ya monday....
SCARABJ is offline
Old 01-15-2006 | 06:44 PM
  #44
TKO
If the 18x33 do not work out and they are 5 blades I would be interested
thanks,Walt
TKO is offline
Old 01-15-2006 | 06:49 PM
  #45
JCPERF's Avatar
thanks,Walt
They are 4 blades
JCPERF is offline
Old 01-15-2006 | 06:50 PM
  #46
SCARABJ's Avatar
AKA NORTECHJ
thanks,Walt
hey quit trying to horr in on my props
SCARABJ is offline
Old 01-15-2006 | 07:14 PM
  #47
ratman's Avatar
Oh yeah JC thanks for those early style converted dry sump 6,s ya sold me last night from that Dude in Va. Sh@t! I hope He,s not a member here.
aren't those drives overkill with the new power? won't he go faster with alphas and less parasitic hp loss thru the drives?
ratman is offline
Old 01-15-2006 | 09:04 PM
  #48
44MTI's Avatar
From speaking with scism and a few others the main advantage in swept back skegs is improved handling. This is especially true with the older, pre 01 I think skegs. Merc has obviously gone to a swept back style, with a couple of variations, but even they need work in the higher speeds. Shouldn't effect you.
I had a 99 42' fountain with dry 6's, that some jack a$$ had filled according to a wet sump. I called Fountain and talked to them about it and Jeff Harris told me they had never seen less than 3 mph increase and as much as 5-6 mph increase in going to the dry sump. Hope this helps. I personally don't think you will see enough of an improvement to justify the cost on a single, but you never know.
PS: Bird man is going to need more than newer power to hang with the E-Dockers.
44MTI is offline
Old 01-15-2006 | 09:15 PM
  #49
JCPERF's Avatar
I thank you and byrd says screw you
JCPERF is offline
Old 01-15-2006 | 10:06 PM
  #50
Coolerman's Avatar
PF Marine
What handling characteristics do the swept back skegs improve?
Coolerman is offline
