drives...yes or no question >
Old 01-23-2006 | 05:42 PM
375stinger's Avatar
Default drives...yes or no question
okis...i just need a simple straight forward response for this question...will raising the x dimension lower the bow lift?thank you
375stinger is offline
Old 01-24-2006 | 12:25 AM
Default Re: drives...yes or no question
maybe
If the X is real deep, then probably not.
Griff is offline
Old 01-24-2006 | 12:26 AM
stecz20's Avatar
you will get some better answers in the tech section... thats where the smart guys hang....
stecz20 is offline
Old 01-24-2006 | 06:06 AM
PatriYacht's Avatar
That's what the trim switch is for.
PatriYacht is offline
Old 01-24-2006 | 07:10 AM
cuda's Avatar
Well, yes and no.
cuda is offline
Old 01-24-2006 | 07:11 AM
cuda's Avatar
Is that why we never see you in there????
cuda is offline
Old 01-24-2006 | 10:21 AM
375stinger's Avatar
well if the drives are too low...
Old 01-24-2006 | 10:26 AM
birdog's Avatar
That would be why I'm here..............
There is no..Yes or No...It depends. deeper,spinning in should carry the bow more...Maybe
Now throw props into the equation also.....
birdog is offline
Old 01-24-2006 | 11:04 AM
Ted G's Avatar
All other things being equal raising the x will cause the bow to drop. If the drive is higher it exerts less leverage and drops the bow. Some boats get extensions at the same time to bring some of the leverage back. But if you just move the prop up (like an outboard with a jack plate) it will drop the bow at the same trim position.
www.cbpba.com
Ted G is offline
Old 01-24-2006 | 11:25 AM
WildWarrior's Avatar
Raising the drive height from stock Bravo X on your style hull will lower your bow, and if she porpoises now even a little bit ,she will be like flippers older brother with less X and also net way slower speeds.
WildWarrior is offline
