Need Engines...... ...... ..need Engines >
Old 02-10-2006 | 10:04 PM
  #31
WeaponX's Avatar
Default Re: Need Engines...... ...... ..need Engines
Originally Posted by customryder
you meant run from... i cant keep up.....but can i have one of those like in your avatar now?
That's one of the (French benefits) of a fast cat. The shirt or whats in it????
WeaponX is offline
Old 02-10-2006 | 11:53 PM
  #32
LubeJobs42's Avatar
Originally Posted by wiggler4490
I think you will find that a 100-105mph nortech will be a ton less than a 125-130mph boat, over 850hp open wide. If you use it on loto, the 525's will push you as fast as you want to go. On the weekends 85-90 is all you want bvecause it is so crowded and rough, you just wont run 125mph but maybe twice a year there.
I disagree. You don't buy a Nortech which is one of the hottest looking boats out there to have 80% of the boats out there pass you by. Nothing ruins your day quicker then having your A$$ kicked. That's why Corvette, Lamborgini and Ferrari don't have an optional 4 cyl engine! I have 2 friends with 36 Nortechs with 525's. Both of them are currenty upgrading to bigger power because they are tired of showing up 30 minutes after the rest of us.
LubeJobs42 is offline
Old 02-11-2006 | 12:35 AM
  #33
Dregsz's Avatar
I can do a pair at that price, to your spec.
http://www.offshoreonly.com/esvon/page-6210.html
Evan
need a pair complete....525, 575 merc. or custom 600-750 hp
Please PM or call 270 442 1777 must be reasonable 25- 35k
Thanks Jeff
Dregsz is offline
Old 02-11-2006 | 08:19 AM
  #34
I have a friend looking to sell a pair of fresh Sterling 850's for $50k complete ready to use.
800XCR is offline
Old 02-11-2006 | 09:34 AM
  #35
I was just suggesting a warrantied, reliable, yet still insurable option, and if the boat is to be used at loto for weekend use then the 525/arneson which should be a 110+ mph boat would be plenty of power and more speed than you can safely run. Depending on where you are located on the lake you cant run any faster due to traffic. If the boat is going to be used on the poker run circuit or the owner needs to be up at the front of races then go with big power, that is if you can get insurance and afford it. for poker runs the Nortech 850's are a nice package, however I believe that boat has #6 arnesons on it which I believe are rated at 750hp. the 850's will push you close to 135mph.. just trying to help with your decision
Buddy OO is offline
Old 02-11-2006 | 09:52 AM
  #36
Hauling Trash's Avatar
Heres a pair of 750 Sterlings with 1 hr on them .
FIRESALE price $30.000.00 for the pair.
Mike
Attached Thumbnails Need Engines...... ...... ..need Engines-mvc-001f.jpg   Need Engines...... ...... ..need Engines-mvc-004f.jpg   Need Engines...... ...... ..need Engines-mvc-002f.jpg
2014 OPA-APBA National Champion Class 7 .Hauling Trash 725.
Hauling Trash is offline
  #37
Ky lake is very long plenty of room with no traffic. Just a few water-flees & fish-heads
customryder is offline
Old 02-11-2006 | 10:07 AM
  #38
what would it take to make these useable? detune decress rpm? to much trouble?
509 CI
Peak power @ 7200 RPM
Max power 800+
Mechanical fuel pumps included
Daily dry sump pump and engine plumbing
Twin bell housing cooling system
Single stage Mercury water pump
Jessel belt drive
Spring oilers in valve covers
MSD billet distributor
Demon 1095 Carb
Attached Thumbnails Need Engines...... ...... ..need Engines-imgp4086%5B1%5D_00-custom-.jpg   Need Engines...... ...... ..need Engines-imgp4083%5B1%5D-custom-.jpg
Old 02-11-2006 | 10:54 AM
  #39
Dregsz's Avatar
Mike
That's a good deal
Dregsz is offline
Old 02-11-2006 | 11:44 AM
  #40
WeaponX's Avatar
509 CI
Max power 800+
Jessel belt drive
Demon 1095 Carb
Why detune? Just don't turn the 7200rpm and they should last for a little bit. It's just the 110 octane. $$$
WeaponX is offline
