Amp Troubleshooting
Old 03-21-2006 | 06:23 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Default Re: Amp Troubleshooting
from the manual I dont see a internal fuse location here are some hints froim the manual
NOTE: If you are having problems after installation follow the Troubleshooting procedures below.
Procedure 1: Check Amplifier for proper connections.
Verify that POWER light is on. If POWER light is on skip to Step 2, if not continue.
1. Check in-line fuse on battery positive cable. Replace if necessary.
2. Verify that Ground connection is connected to clean metal of the vehicle’s chassis.
Repair/replace if necessary.
3. Verify there is 10.5 - 15.5 Volts of current present at the positive battery and remote turn-on
cable. Verify quality connections for both cables at amplifier, stereo, and battery/fuseholder.
Procedure 2: Check Amplifier for audio output.
1. Verify good RCA/high-level input connections at stereo and amplifier. Check entire length of
cables for kinks, splices, etc. Test RCA/high-level inputs for AC current with stereo on.
2. Disconnect RCA/high-level input from amplifier. Connect RCA/high-level input from test stereo
directly to amplifier input.
Procedure 3: Check Amplifier if you experience Turn-on Pop.
1. Disconnect input signal to amplifier and turn amplifier on and off.
2. If the noise is eliminated, connect the REM lead of amplifier to source unit with a delay turn-on
module.
OR
1. Use a different 12 Volt source for REM lead of amplifier (i.e. battery direct).
2. If the noise is eliminated, use a relay to isolate the amplifier from noisy turn-on output.
Procedure 4: Check Amplifier if you experience excess Engine Noise.
1. Route all signal carrying wires (RCA, Speaker cables) away from power and ground wires.
OR
2. Bypass any and all electrical components between the stereo and the amplifier(s). Connect
stereo directly to input of amplifier. If noise goes away the unit being bypassed is the cause of
the noise.
OR
3. Remove existing ground wires for all electrical components. Reground wires to different
locations. Verify that grounding location is clean, shiny metal free of paint, rust etc.
OR
4. Add secondary ground cable from negative battery terminal to the chassis metal or engine block
of vehicle.
OR
5. Have alternator and battery load tested by your mechanic. Verify good working order of vehicle
electrical system including distributor, spark plugs, spark plug wires, voltage regulator etc.
klaw is offline
Old 03-21-2006 | 06:30 PM
UNSANE's Avatar
Originally Posted by Boomer35
there is a LED, and it does not lite up, no power at all
Ok, sounds like a power supply problem, you might be able to get it fixed, but be prepared to write this one off. How long has it been sitting around? Sometimes just moving a piece of gear can screw it up.
UNSANE is offline
Old 03-21-2006 | 06:33 PM
klaw's Avatar
if you have power to amp and power to remote turn on and led doesnot light up prob liss it goodby
klaw is offline
bajahaha
Drives and Lower Units
1
06-25-2007 08:09 AM
dean51267
1
08-20-2006 06:50 PM
georges
Pantera
11
12-18-2004 08:26 PM
Miller
5
06-13-2002 03:17 PM
Risk Taker
03-07-2002 08:22 PM
