Bravo 3 Drive - max top speed >
Old 05-12-2022 | 10:21 PM
Default Sea Ray 240 sundeck
Originally Posted by 496power
What is the max top speed a boat can go with a Bravo 3 drive ?
I heard about 60 MPH is the limit ! ?
I had a bravo 3 hooked up to a 24 ft Sea Ray sundeck with a 6.2 multiport injection motor. When coming out of the water the boat was never sluggish and jumped out of the water the front end didn't rise the whole boat would rise and take off like a bullet... With a quarter tank of gas and me alone on the boat I could get that boat doing 62 or 63 mph
Paul Bershatsky is offline
Old 05-13-2022 | 06:17 AM
My early no arch no gen formula 330ss could run a tick under 60 with 330s. Would have been really fun with 502 mags.
hogie roll is offline
Old 05-13-2022 | 01:26 PM
They did make an XR B3 to handle the torque of 525. I believe the biggest pitch for a stock blade pitch was 30. Unless you are going to build a custom set of props and max out the HP that a stock B1 upper can handle it's not a cost effective speed solution.
The B3 is great in single engine runabouts in the 15 to 30 foot range. But 60-70 mph is about it.
techman is offline
Old 05-15-2022 | 10:58 AM
Would the Black Hawk lower fit on the Bravo 3 upper? I’ve always wondered how they would work on my Velocity..
Powerquest230 is offline
Old 05-15-2022 | 12:46 PM
The black hawk is a 1 piece case, it doesn’t split in half like the rest of the bravos do
JaayTeee is offline
Old 05-15-2022 | 01:49 PM
There is no B3 upper, the top is a standard B1 with X or XR gears.
techman is offline
Old 05-15-2022 | 07:51 PM
We were able to get 87mph with our single engine Bravo 3. It was a 1.5 gear ratio, but I do not recall the pitch of the prop. That said, the prop guy cut a ton off of those big ears to get it spinning faster. We also added a nose cone.
36Tango is offline
Old 05-16-2022 | 05:22 PM
The 33 scarab with DPXs and 600 innovations was very speedy
Old 05-17-2022 | 10:23 AM
Rookie's Avatar
Perfect setup for that hull.
Rookie is offline
Old 05-17-2022 | 08:31 PM
Have a 2000 226 Cobalt with a stock 7.4 MPI. Corsa silent choice exhaust bravo 3 29P prop with a 1:2 ratio. Best speed 1/2 tank of fuel slight chop. Next speed 63.5 mph on gps
3pointstar is offline
articfriends
1
07-30-2006 08:10 PM
G Man
3
08-29-2005 02:59 PM
Buddy OO
05-17-2004 12:23 PM
superstar
2
12-04-2003 05:50 PM
Steamin Rice
15
08-14-2002 05:32 PM
