Dangers of Tunnel Tab on 36 Spectre Cat?
I have a big tab on my 05 30' Spectre and love it. I don't use it at all above 80 ish. I lift it as the boat lifts. I only use it to reduce the porpoise at that magic speed. But like I said I lift it as I go faster, use what tab is needed and that is it. When I lay the sticks all the way forward I have already lifted the tab past neutral. PM Maximus with your number he will give you some great advice and you can call Jay at Spectre he will be more then happy to give you some advice. And both of those guys won't give you advice on how to go faster with a tab rather how to use it for what it is on your boat for.
Andy
Andy
Originally Posted by Andy01
How much is the Tres class? How long and where is it located?
He is real easy to talk to just give him a call.
http://www.performanceboatschool.com/
It was alot of money for me to spend but i will tell you that i think it is more than worth it. unlike some people here i don't know everything about boats and the stuff he covers is for both TS and cats.
One thing I learned in the smaller boats and it has stuck in my head ever since.....
While running a tunnel boat at speed and the compression in the tunnel gets so great that the boat feels flighty, as much as your head tells you to back off the throttles you have to fight it. You need to literally drive out of it and tuck the drives in a bit to bring the bow down.
If you were to chop the throttles, the transom would then drop, cutting off the exit for the air in the tunnel which then would cause an instant blow over or barrel roll depending on where the greatest lift is at the moment...
I am not sure what it would take to do that in a bigger boat, but the smaller ones, it could happen as little as 60 mph...
Also, Pat Patel & Doug Lewis flipped in testing due to a tunnel tab at high speed.
As you see, it can happen to the best of us.
Take the advice, once running at high speed, leave the tab up...
Also, Tres's course sounds like a great one!
Best of luck!
Best of luck!
