Re: liferaft question
Originally Posted by iamfaster
So, basically you will do fine with floaties.... Im watching you MOFO
:eek: |
Originally Posted by GOODT
Im looking for someone that inspects liferafts in the annapolis maryland area
Air Works, The, 10 Lincoln Court, Annapolis, MD, 21401, USA, (tel) 410-268-7332, (fax) 410-280-5225 Inflatable Xperts 306 2nd St (410) 263-1496 Annapolis, MD 21401 |
Try Lifeline inflatables in Miami (305) 621-1500 or 84 boat works in ft. Lauderdale (954) 779-7000 you cane sometimes find a good certified used one as well at these places
Dan,
I bought a small Mercury stowable tender (plank floor/ rated for 5hp) and a 12 volt quick inflate pump. I use my jumper and inflate the boat in 50 seconds right off of the swim step. I have a 2.7hp cruise and carry 2 stoke outboard to go with it. The tender, motor and pump together weigh about 60 pounds and stow safely in the head closet. The whole set up cost less than a $1000 new. I use it in Catalina but it is also a good back up in case of trouble... |
| All times are GMT -5. The time now is 12:34 AM. |
