liferaft question
Old 05-24-2006 | 10:35 PM
SLOWOUTBOARD's Avatar
Default Re: liferaft question
Originally Posted by iamfaster
So, basically you will do fine with floaties.... Im watching you MOFO
your alittle slow with your post duaner JUST LIKE YOUR BOAT
SLOWOUTBOARD is offline
Old 05-24-2006 | 10:57 PM
Ted G's Avatar
Originally Posted by GOODT
Im looking for someone that inspects liferafts in the annapolis maryland area
Try these guys:
Air Works, The, 10 Lincoln Court, Annapolis, MD, 21401, USA, (tel) 410-268-7332, (fax) 410-280-5225
Inflatable Xperts
306 2nd St (410) 263-1496
Annapolis, MD 21401
www.cbpba.com
Ted G is offline
Old 05-25-2006 | 07:48 AM
Try Lifeline inflatables in Miami (305) 621-1500 or 84 boat works in ft. Lauderdale (954) 779-7000 you cane sometimes find a good certified used one as well at these places
XtremePowerboats.com is offline
Old 05-25-2006 | 09:21 AM
rickdarling's Avatar
Dan,
I bought a small Mercury stowable tender (plank floor/ rated for 5hp) and a 12 volt quick inflate pump. I use my jumper and inflate the boat in 50 seconds right off of the swim step. I have a 2.7hp cruise and carry 2 stoke outboard to go with it. The tender, motor and pump together weigh about 60 pounds and stow safely in the head closet. The whole set up cost less than a $1000 new. I use it in Catalina but it is also a good back up in case of trouble...
rickdarling is offline
jaxx 30
Scarab
5
04-10-2008 09:49 PM
1Boatnut
02-20-2002 09:22 PM
