twin engine docking tips?
Old 05-30-2006 | 08:12 AM
fund razor's Avatar
Default Re: twin engine docking tips?
Originally Posted by MOP
I taught boat handling for 6 years included in the mix were some nasty powered ones, most I/O's tend to have the engines set to close for good up close maneuvering and are usually far better off docking on one engine. Try one engine docking and you will see little to no difference using either engine, the plus is you will get into less trouble as things happen in a more manageable fashion. I/O boats will always go in the direction the drive is turned steering works better then shifting. For one reason or another most boats have one engine that never dies and one that can be finicky, I always told my clients do your docking with the finicky one, if it craps out there is -0- panic simply grab the reliable ones shifter and finish docking. Using that practice has stood well by many of my customers over the years, try it many will find it may make your life easier.
Phil
Great post. A 26 footer is probably an 8 foot beam and the I/Os are probably close together. Add that to the fact that the props extend so far behind the boat (as opposed to inboard screws which would be closer to midships) and you are better off docking a narrow twin I/O on one side.
Let the combined effect of the wind and current act as one screw, and use one side of the boat to counter that force= the ability to go zero to one-half mile an hour around the dock.
Using the trannies/screws for manuevering works great with fat cruisers with widely spaced screws far inboard of the transom.
But not for small I/Os.
I have a 26 footer with twin I/Os and I dock on one side.
fund razor is offline
Old 05-30-2006 | 09:05 AM
LostinBoston's Avatar
Originally Posted by CBR
I am still trying to get fast drift stern docking right after a lifetime of doing it. Always helps to have someone on their boat with their feet out to keep you from swinging sideways into their boat. <gg>
Tres goes over some great fast drift docking tips that helped me out greatly.
Also, Boating mag has an article about a docking tournamnet in MD with some great tips as well.
LostinBoston is offline
Old 05-30-2006 | 11:54 AM
Are boats with drives/props set to turn in vs out when going forward more difficult to back up ?
I have a very difficult time backing my boat with this set-up.
ed
Interceptor is offline
Old 05-30-2006 | 12:27 PM
Canada Jeff's Avatar
I would't shut one engine off. If you can't dock it with the sticks and you have to dock it like a single, at least keep it running. Only one engine with a power steering pump.
Canada Jeff is offline
Old 05-30-2006 | 12:31 PM
If the boat isn't a staggered setup, using the sticks works just fine. I leaned on cruisers from 25 to 43 footers as I grew up. Making the transition to a 36 pache was no problem at all.
Practice!!!!
Old 05-30-2006 | 02:28 PM
fund razor's Avatar
First of all... a 36 Apache is NOT a small I/O.
If you learned on cruisers you know that a boat with I/Os just can't leave a seawall sideways like a cruiser with twin IBs and rudders.
There is a fundamental difference between having the props under the boat and spread versus a couple feet behind and 18 inches apart.
Plain and simple. There are moves that I can make with inboards that I can't possibly make with I/Os.
But I'll keep practicing jeff.
Old 05-30-2006 | 02:35 PM
I explain our situation, not everyones. But it can be done relatively easy with a 36 foot fast boat with I/O . I wouldn't dare try it with one drive only.
Old 05-30-2006 | 05:22 PM
ed
Every V hull I've driven with inside rotation
has handled poorly around the dock.
The difference appears to be whichever one is in
reverse, it doesn't seem to have much "pull".
The only thing I can factor to this is that the water
off the props ( on the keel side of the drives) are
being thrown upward, and hitting the V portion
of the transom, reducing total reverse thrust
of that prop.
JaayTeee is offline
Old 05-30-2006 | 06:36 PM
satisfactionII's Avatar
Originally Posted by Fountain38SC
I think there is only 1 really good rule of thumb.
DO NOT APPROACH THE DOCK FASTER THEN YOU WANT TO HIT IT!
Rule one above
Rule two below.
Don't hit anything any harder than you are than you are willing to pay for!
satisfactionII is offline
Old 05-30-2006 | 07:28 PM
eyezlee's Avatar
I read a small piece on docking and the author said to imagine yourself standing in the middle of an X. If you do this, you will always know which drive to engage to move the boat the correct way. This is very similar to sydways info above and it works for me.
Netural is your friend. I don't know how many times I've said this to my wife as she's learning to drive as well.
eyezlee is offline
