Running a LH prop - drive question >
Old 06-06-2006 | 05:10 PM
eMotiondriver's Avatar
Default Re: Running a LH prop - drive question
HuMMMMMMM. So your saying my service people lie, or are confused, and numbers are for a different price ???
Just a question?
eMotiondriver is offline
Old 06-07-2006 | 12:14 AM
I'm saying they are like a lot of "techs". They look in a book for the answer and whatever the book says is the way it is.
I'll bet they would charge over 6k for new standard Bravo 1 drive as well when they are available all over for around 4k. The "book" will list that as retail price.
There are some differences from early Bravos to newer ones, and the newer X, XZ, and XR. But the bottom line is all of them can be run in either direction.
Griff is offline
Old 06-07-2006 | 08:19 AM
http://www.offshoreoutdrives.com
Brian will answer as he is a small shop and he will answer the question correctly
OffshoreOnly is offline
Old 06-07-2006 | 09:01 PM
mwdill's Avatar
has anyone tried it on a single engine stepped hull?
mwdill is offline
Old 06-07-2006 | 09:46 PM
99fever27's Avatar
Originally Posted by 99fever27
My boat was set up for a LH..like a dummy I bought a RH, switched the linkage with no problem. Although it is in the shop for a drive issue.... I think its unrelated though.
Yup
99fever27 is offline
Old 06-08-2006 | 04:46 PM
You are correct, you can run these drives either way, I've done it, but there is a differnce in the bearings, thrust, clutch cone, etc,etc,etc tolerance's as far as direction. I guess they finally figured it did not make a difference.
I only call for part numbers, then I call Mercury with a dealer number, so price is not what U believe.........
Old 06-08-2006 | 09:56 PM
articfriends's Avatar
What I have heard is if you want to run a bravo L/H with big power is to put a billet cap and studs on like max worx uses to help prevet flex on the cap,with stock power makes no difference. I have flipped the upper (l/h) and lower (r/h) top gears over before while rebuilding my own drive to put even wear on the gears as I run my always R/H,Smitty
articfriends is offline
p729lws
Drives and Lower Units
10
01-18-2008 11:37 AM
grimmy
03-01-2007 06:47 PM
grimmy
Prop Talk
3
03-01-2007 06:45 PM
imongo
15
05-02-2002 08:50 AM
imongo
Cigarette
6
04-30-2002 06:39 PM
