Beep, Beep, Beep?????
Old 09-06-2006 | 09:14 PM
fatdaddy's Avatar
Default Re: Beep, Beep, Beep?????
Originally Posted by wrinkleface
On a Formula I had, the bilge pump under the cabin entry step "it was stuck on". There is a little button to push or slide to get it "unstuck"! good luck
Interesting? But if this was the case wouldn't it stay continuously beeping until I got it unstuck?
fatdaddy is offline
Old 09-06-2006 | 10:13 PM
Charter Member #415
Most of the time it is the gear lube monitor. But if you eliminate that,there are 27 other things that set off the beep. Eliminate the gear lube ,then get a Merc dealer to plug in his scan tool.Shouldn't cost a lot,and then you will know for sure. But 99% of our problems are gear lube.
Magicfloat is offline
Old 09-06-2006 | 10:42 PM
fatdaddy's Avatar
I agree. Will probably pull boat this weekend, summer is coming to a quick end in NJ, and will have it scanned when sch'd for winterization.
fatdaddy is offline
Black Tornado
Classic Offshore
42
04-06-2015 11:07 PM
apexer
4
05-09-2008 01:21 PM
Reckless32
54
07-03-2007 11:24 AM
fatdaddy
Baja
3
09-06-2006 10:57 PM
Fast Shafts
General Racing Discussion
10
05-10-2003 09:01 AM
