Trim Tabs size?
Old 09-08-2006 | 01:54 PM
fruitta55's Avatar
Default Trim Tabs size?
Is there such a thing as too much trim tab? As in what would be too big for my 24' Banana or any other similar 24' boat?
fruitta55 is offline
Old 09-11-2006 | 08:29 AM
Air Dog's Avatar
Hey Fruitta,
Most Banana Boats came from the factory with 280 K-planes. The only exception was the single engine boats such as yours and mine that had none as they weren't really needed because of the slower speeds.
I always said that with my 200hp merc hanging on the transom all I needed was a tab on the left side. Reason being is with the prop spinning clockwise, the bow would hit a bit harder when taking a wave to port.
If your running single engine, then I can say for sure that any type of tab will work.
The exception is if your running set back or a surface running prop.
Last year I ran 18" of hydraulic setback and a 20" shaft with approx 350hp running on the surface. Lots and Lots of torque and I had not installed any tabs yet.....
As for the longer tabs? If your running on the transom, then the 380 tabs are a waist of money, unless you are going to run them flat (meaning parrallel to the water, not the shape of the hull), then it is a great idea.
If your using any set back greater than 5-6 inches, then 280s are more than enough.
If your going to hang on the transom single engine, then save a bunch of money and throw some bennetts on the back.
Hope I helped...
Attached Thumbnails Trim Tabs size?-banana-boat-027-small-.jpg   Trim Tabs size?-transom-small-.jpg
Air Dog is offline
Old 09-11-2006 | 09:56 AM
fruitta55's Avatar
Default Re: Trim Tabs size?
Thanks Airdog, I do plan on running with a bracket. I want to do away with the well and close in the transom. Any idea what the dimensions are on the 280's?
26sonic
Sonic
8
06-23-2009 09:14 PM
dloftis
Baja
8
03-12-2009 08:08 AM
ItsPeanut
1
04-14-2008 06:23 PM
doms1214
08-17-2006 10:44 PM
dallas01
Baja
7
01-05-2003 05:27 PM
