Seadoo RXT vs Yamaha FX waverunners
#31
Originally Posted by mcollinstn
Honda is the best fit/finish
Yamaha is the most reliable overall (yes, the mid-gen powervalve motors need retainer clips on them to be safe, and the early GPR1300's had grate fasteners pulling thru the hull).
Kawasaki is the third of the Jap skis, but some of their models are real jewels. Nothing really to knock except for some of the early STX's handling horribly and the Ultra150 with its tendency to spit you over the high side at 60+ on occasion (I have one and love it, but it does give big purple and yellow bruises on your butt when it flyswats you).
All of the Jap mfrs spend a lot of money on R&D before they release a unit to the public. They can have some bugs but are generally well sorted.
SeaDoo spends their money on marketing. Good units, inferior finish work when compared to the japs, but they are quick to let the customers be their research team. Warranty nightmares, and lots of denied claims.
The 06 supercharger clutch in the 'Doo is much improved and far beefier. Took em 4 years of denied warranty claims and emptying customers wallets to get a new upgrade, but it is here. It still needs the ceramic washers replaced with hardened steel ones if you plan to run it hard in rough water. The first year supercharged boats also had plastic pump housings. They got that right the second year. Things like this kill the resale value on the units with the badly engineered pieces. At least the pump housing upgrade is relatively easy to do.
If you plan to get a supercharged Doo, then get an 06.
The old rotary valve Doo motors were bulletproof, but they NEEDED to be. Of all the skis I've dragged behind my boats on a rope, the Doos were the only ones that would completely fill their crankcases with seawater flowing into the motor from the exhaust. They also had a few years of questionable crankshafts which flaked the chrome off the journals.
The Rotax 4 stroke triple is a good motor. The GTX / RXP is a good hull and is a lot of fun. But stick with an 06.
The supercharged Kawi is going to be one heck of a boat. I am going to put it on my wish list.
#32
Originally Posted by pm203
My Seadoo dealer tells me along with the specs from the brochure that both the RXP and GTX limited have the same hull/bottom.
#33
Originally Posted by OffshoreTom
You should check your brochure again I think. GTX is longer and has features to prevent spray.
#34
I have 2 Yami's. I tested the the Seadoo 215 hp and did like the acceleration, but ultimately went with the 160 Yami and a 1300 (2-seater) Yami. My wife usually takes the 3 seater and loves the dry ride along with reliabillity. I realllllllllly like my 1300 since I just hit 77 gps (heavily modded)!
#35
Here is the low down
Get the honda if you want to have a very reliable boat that isn't the greatest at any singel thing but being reliable. Good boat yea, but not the fastest or best handling.
Get the Yami if you want to go do spins. These are usually the people that think they look cool, but everyone else knows better.
Get the Sea Doo if you want a balls to the wall fast ride. And be look cool while on the Doo.
But get the extended warranty because you'll need it.
Doo has two offerings though, RXP and RXT. Good luck and have fun. Stay out of everyone's way. And beware of the new rider that gets confident, those are the ones that get into trouble.
#36
They are identical hull dimensions. The Limited was approx 5 pounds heavier.( probably due the extra stuff it comes with)There might be something extra there to deflect the water, but length, width, etc is showing absolutely the same.
GTX Limited hull - 130.3"
RXP hull - 120.9"
#37
The GTX and the RXT-ank have the same hulls and are 3 seaters at 130 inches, the RXPeePee is a 2 seater and is 120 inches... and I wouldn't own any of them... go kawi, or yammi...
#38
The kawasaki w/ 250 hp sounds nice, but I hate to buy anything that has just has been introduced.
#39
Great ride and adequate power. Loved it.
#40
I can't believe i'm going to say this BUT, the RXT isn't a bad machine at all,, save for the ceramic washer problem they are a descent machine. They have increased the size of the cearmic and it is more reliable, but there are still failures, the metal washer fix seems to be working too. I've also heard they put the RXT on a diet for 07 and it lost 55 lbs.. It's rumored they cut back on the glass and resin to save money so they wouldn't have to raise the price. so now hull integrity seems like it could possibly be an issue, only time will tell on this issue... Sea-Bomb IMO has always had questionable warranty practices and like has been said, usually the consumer is their testing guinea pig...
