I amaze myself every day! Dingy problem! >
Old 10-15-2006 | 04:10 PM
LubeJobs42's Avatar
Default Re: I amaze myself every day! Dingy problem!
Originally Posted by el indio
Not knowing how to handle a dingy and you run that cat.........SCARY!!!!!!
The cat dosen't use 2 cycle oil, maybe that's the differance.
LubeJobs42 is offline
Old 10-15-2006 | 04:16 PM
TeamSaris's Avatar
Driver-441
Racer
Hydraulic trim and a ss prop (labbed by BBLADES preferably mine is) will make all the difference in the world. Thats what we did to the min.
TeamSaris is offline
Old 10-15-2006 | 04:17 PM
TeamSaris's Avatar
Driver-441
Racer
This is what I have.
http://www.cook-mfg.com/pt35.html
Old 10-15-2006 | 04:30 PM
LubeJobs42's Avatar
I was planning on keeping this very simple. The prop is about 6 inches below the boat.. I think it's not deep enough. I was told you don't need a long shaft with a boat this size.
Attached Thumbnails I amaze myself every day! Dingy problem!-25-merc-2-large-.jpg   I amaze myself every day! Dingy problem!-25-merc-3-large-.jpg   I amaze myself every day! Dingy problem!-25-merc-large-.jpg
Old 10-15-2006 | 04:56 PM
mr_velocity's Avatar
Looks like the pin isn't in the bottom hole. Prop is definitely deep enough. Worse case add a transom wedge to give the motor a little more negative trim.
mr_velocity is offline
Old 10-15-2006 | 05:06 PM
LubeJobs42's Avatar
There is one more hole I can move the pin to. When you say add a wedge, where would I put it?
Old 10-15-2006 | 05:15 PM
Goes between the motor and the transom.
Search Ebay for Transom Wedge, they're like $30.
Old 10-15-2006 | 06:35 PM
Audiofn's Avatar
Charter Member #232
Ya I am going with move that pin down. There is NO WAY you need a longer mid section on that thing. If it was me I would put a block under the transom bracket to raise the motor up even more. Get that thing so that the prop is just under the bottom.
Jon
Put your best foot forward!
Audiofn is offline
Old 10-15-2006 | 06:53 PM
SPITFIRE's Avatar
Where are you sitting? We always used extension poles into the throttle handle so we could move weight forward. That thing should be a rocket ship though, you'll want to be forward.
SPITFIRE is offline
Old 10-15-2006 | 06:57 PM
Roger 1's Avatar
Did you check the gear lube in the lower unit before you returned the stuff you bought?
Roger 1 is offline
