Tunnel Ram Engines
#101
But if it was a retro fit for old school bbc you could keep the cost way down.
what if u pulled your cam installed another with just drive gear for the oil pump and a drive gear up front to drive a vertical shaft to turn the cams that you made a support cor that anchored in the lifter bores.
Hemi head x flow for flame propigation a double 4 bbl moderate height manifold crank trigger ign to keep the hheads as clean a possible? The manifold could have equal spacing and be straight ports due to not having pushrods.
My shaffiroff 540 was an unclaimed eng. Guy paid 50% deposit and vanished. I paid 13k dragon slayer crabk manly rods full cnc pro 1 heads msd dist. Top of the line everything incl 1050 dominator
That solves the pushrod problem. If you build it Ill come! I'd drop coin on a config like that to try it if it came from a reputable shop.
Sounds a bit like what Mercs doing. Interesting to me they claim an LS base.
Ilmor claims (to their surprise) they had to completely redo the oiling system for sustained RPM running.
I wonder what tricks Merc plays.
Great deal on a zero hour killer BBC.
Whats it in ?
UD
#102
Love this stuff. I had a friend of friend years ago with a 34 sutphen with tunnel ram engines in it. What a beast. One of you Jersey guys probably remember the boat. Someone down there was Dave's "guy".
#103
#104
Whats it in ?
UD
Whats it in ?
UD
The dude that ordered it checked damn near every box for upgrades.
dart block callies dragon slayer crank manley rods je slugs pro1 heads full cnc porting was worth a hundred ponies msd trick everything its living in a 67 pro touring camaro with a full dse chassis setup. Mark stielow desidned all the chassis stuff baer brakes fully adj suspension. 714tq 804hp @ 6500 hyd roller valve train. Im gonna going to swap in a solid roller and spin it 8k... rm
#105
Lucky move picking up someones high quality abandoned project for pennies on the dollar.
UD
