Oil In Bilge
Old 10-31-2006 | 08:25 PM
BY U BOY's Avatar
Default Re: Oil In Bilge
Originally Posted by dgrady
This is a collector that is at the back of the engine, and the hoses run to it. The collector is hung on a custom bracket, and has a drain in the bootom that can be drained after every use. Helps collect the moisture as well. These are usually seen on drag applications but work wonderful on boats...also looks pretty trick.
WERE DID YOU GET YOURS?
THANKS FOR THE PIC.
SO YOU THINK THE ONES THAT ARE USED ON STRIP CARS WORK WELL. WHAT ABOUT THE ONES THAT I SEE ON ALOT OF JET BOATS WERE CAN I GET ONE OF THOSE?
BY U BOY is offline
Old 11-01-2006 | 12:44 AM
Check out the ones offered by imco they work and look great. I run a set on mine and no oil problems and I am blown wich usually creates more psi than naturally aspirated.
Paul
427eliminator is offline
Old 11-01-2006 | 01:22 PM
dgrady's Avatar
http://www.jazproducts.com/index2.htm
This is the web site you need. check it out I think this is what you are looking for.
select the OVERFLOW section on the left of the screen.
dgrady is offline
Old 11-01-2006 | 01:32 PM
StraightJacket's Avatar
You could have a nice aluminum collection tank made, and get an vac pump that GM used on the late 90's camaro/firechickens to pull the crankcase pressure out. and use a good breather to maximize flow though it .
StraightJacket is offline
Old 11-01-2006 | 02:17 PM
BY U BOY's Avatar
Thanks For The Input Guys
BY U BOY is offline
Old 11-02-2006 | 10:42 AM
BY U BOY's Avatar
OK I HAVE BEEN LOOKING AT A BUNCH OF CATCH TANKS THE LAST TWO DAYS AND AM SEEING A LOT WITH OUT BREATHERS AND A FEW WITH THEM ON TOP. IS THE BREATHER NEEDED FOR THE MARINE APPLICATION?
http://cgi.ebay.com/ebaymotors/HKS-O...44322781QQrdZ1
http://cgi.ebay.com/ebaymotors/STAIN...42388658QQrdZ1
BY U BOY is offline
handfulz28
08-25-2006 10:49 PM
sonic28
Fountain
7
07-26-2006 08:09 PM
Powerful Addiction
7
07-02-2006 09:14 PM
gripit
6
06-06-2005 06:30 AM
Love Machine
0
06-14-2004 09:19 AM
