Why mount tabs horizontal
Old 11-27-2006 | 04:03 PM
FeverMike's Avatar
Default Re: Why mount tabs horizontal
Originally Posted by CanDo
Installing the tabs horizontal is a very old idea. Far from cutting edge. CanDo
Very true. They were mounting tabs horizontal 12-15 years ago in A class.
FeverMike is offline
Old 11-27-2006 | 08:35 PM
Originally Posted by F1-00 Racing
do the water flow calcs b4 you decide to mount them. I have them horizontal on my fountain now, but I tried that on the Venom earler this year and I found them to be useless(tabs in down position caught 2 3/4" of a 30" tab) in that position so I went back to matching the bottom. Boat design detirmines alot when making this decision
step or straight bottom?..
open87 is offline
Old 11-28-2006 | 07:45 AM
Ed
Most all of the offshore vee-bottom rigging, hull design ideas, etc., come from OPC racing of the past. The horizintal tab idea came to light in the mid-sixties & was common then. Reggie raced quite a bit in OPC in his youth before working with Mercury as a test boat driver, then a tunnel boat race team driver for Mercury Hi-Performance Division. Old ideas become new again. Ed
Ed is offline
Old 11-28-2006 | 08:11 AM
Depends on what you use the tabs for. If they are for longitudenal (fore and aft) trim, either way is OK. If they are for roll axis control (side to side), then following the bottom contour is desirable. Visualize a couple of extra fat asses on one side, and the boat leaning 15 or so degrees. A horizontally mounted tab would be a great deal less effective because it is at the same angle.
BROWNIE is offline
Old 11-28-2006 | 12:12 PM
Panther's Avatar
Frank's Marine Service
I remember seeing Velocity do this on their smaller boats way before Fountain ever did... Or at least on their pleasure boats.
Anyway, I heard that it helps with high speed stability having them horizontal?
Panther is offline
Old 11-28-2006 | 12:16 PM
mr_velocity's Avatar
Even on some of the big boats, my 41 has them mounted this way.
mr_velocity is offline
Old 11-28-2006 | 12:19 PM
Panther's Avatar
What year is yours again? 97' - 98'????
I didn't see them on the Reggies until a few years ago.
Panther is offline
Old 11-28-2006 | 05:26 PM
96 just like yours
Old 11-28-2006 | 05:52 PM
Panther's Avatar
96 just like yours
Mine is a 95'..
Panther is offline
Old 11-28-2006 | 06:15 PM
Tantrum's Avatar
I think you should install them upside down....that way you can make sure they are way out of the water
Tantrum is offline
