Centrifical Supercharger Sound !
heres a idle video after installing the ext box last june but you really can't hear much so I don't think its what your looking for,Smitty
http://www.youtube.com/watch?v=LMywg-P5Gos
Originally Posted by articfriends
You either had the worst luck in the world,a terrible set-up,incompetent mechanic or some detail was overlooked. I have had 350 plus hours since 2001 running my m3sc on 502 then my 540 as high as 12 psi of boost without EVER melting down ANY motors,Smitty
Originally Posted by dagah2x
Should have fixed the fuel issue after the first melt down....
I run a procharger M1 and yes it does whine at idle a bit more then I would like but im used to it. Also I have a a crane 731 cam and I think its perfect, it will idle at 800 rpms without a problem and sounds real nice too, not too much but definately healthier then stock.
Most people who have had issues with prochargers or any other supercharger for that matter did not have them setup correctly. A stock fuel system just is not good enough to run over 3psi.
Bottom line I LOVE the sound.....
Just sharing my previous experience with Centrifical SC. Was so long ago, seems like a bad dream. Moved on to bigger and better things.
Originally Posted by AppSysCons
Tried supstantial upgrade on fuel system. See photo of the upgrade.
Details man we want details.....
Originally Posted by Bryan Rose
Still would likm,e to know about the system you used.....as well as motor type 502 mag....500 efi....etc.... and more details about the fuel system upgrade....injectors and such......can you be more specific? procharger or vortec.....etc......
See post #6, my system was a ProCharger Stage III, M3, with a very large intercooler.
2000 season were HP500 carb motors, with lots of upgrades. First season was original carbs with upgrades.
2001 season were HP500 carb motors, with more upgrades and re-done to 509cid. Second season was Nickerson carbs, custom built for the application.
I do not know if I just had bad luck, or other issues raised by atricfreinds in post # 15. Others have done similar upgrades and love them.
For me personally, as I said in post#9, I would NEVER use them again.
What boat are you running that in & what kind of speed are you seeing. I am definatly going to make try to make shure my carb is right from the get go.
Originally Posted by littledcsrodshop
Thanks Smitty, The boat sounds awsome to me in the video.
