single v bottom with #6
Old 03-07-2018 | 06:38 AM
  #121
Interesting. Did you try a 5 blade? How high did you start and where did you end up with what speed and slip?
IGetWet is offline
Old 03-07-2018 | 08:11 AM
  #122
We started out 3" above the bottom. The boat bow steered. I didn't try a 5 blade because more blades causes more transom lift and that was already the issue. The top speed was 120 with 16% slip.
check300 is offline
Old 03-07-2018 | 09:58 AM
  #123
How deep did you end up with the 4 blade? We’re you able to get good bow lift with the 4 blade?
IGetWet is offline
Old 03-07-2018 | 10:10 AM
  #124
We ended up 3 below the bottom. The boat was a straight bottom with a notch. I ended up using a 3 blade. My setup didn't even like a 4 blade. I probably could have come up a little (maybe a half inch) and reduced the slip but I decided 120 was enough .
check300 is offline
Old 03-08-2018 | 04:29 AM
  #125
Originally Posted by mickeymcclgn
i think like said by others you’d need big HP to make up the difference for the added hassle. It would be a good place to start but I would bet you could maybe lower the drive some. Check 300s old checkmate was a 6 I believe 3 below the bottom. My boat however did not like the drive that low. Been there and was disappointed. The more I raised the drive the better the boat handled and the faster it went.
A 1100-1200 HP engine and the Velvet 72L-HP is waiting in my workshop.
The one starts above and ends below bottom. The other starts below and ends above.
​​​​​​Think it's difficult to say what's best for me now.
Chris12 is offline
Old 03-08-2018 | 05:54 AM
  #126
It’s easier to come down than go up. Not sure what the biggest spacer is for the #6, 2”?
IGetWet is offline
Old 03-08-2018 | 07:15 AM
  #127
3"
check300 is offline
Old 03-08-2018 | 07:55 AM
  #128
TeamSaris's Avatar
Driver-441
Racer
We re-rigged this Squadron last year. Runs so nice we have another client buying a 27 so we can do the same setup.
1200EFI
SSM6
100+ through anything
TeamSaris is offline
Old 03-08-2018 | 10:12 AM
  #129
PigNaPoke's Avatar
1200EFI
SSM6
that little rig is sweet.
PigNaPoke is offline
Old 03-08-2018 | 04:36 PM
  #130
TeamSaris How much below or above bottom
​​​​is the shaft ?
Chris12 is offline
